cheers......what by melting the plastic with it and letting it stick together? bit reluctat to try incase i do f*** it up....
if the side skirts are made from ABS plastic ( or polypropelyne), all you need is to get some of the same type of plastic and cut it into thin strips, kinda like solder.
Then proceed to weld it together using a soldering iron and the plastic strips as a filler rod. Do a good enough job and reinforce it with some fiberglass bog, goos as a bought one.
There is a place out at Greenfields (they have a sign for plastic repairs) - you turn in off Port Wakefield Road .... not sure of their name though.
On a side note, when did you buy a 34GTR Mike?
where would i go about getting the filler poly..? i might have a sus of these guys at greenfields then- if its not a hard job hopeflly they can sort it out for me cheap rather than me make a mess of it whic could quiet likely happen...
JIS had a pair of sideskirts.. were after 250$ plus mark from memory......mmm thats about the price of 3 cartons of jacks...:P Cheers for the help
if you get it plastic welded , you will probably need it resprayed as by plastic welding there would be a line of where it was broken if you do one side, if you do both sides it will still need to be redone as it leaves leftover plastic and is not colour coded and needs to be sanded down to be all flush again.
Just my 5 cents worth on the topic.
Hey Andrew,
Yeah bought one about 2 months ago now. its been 3 years since i sold my 33. Too long.
Will have to catch up with everyone, organise a cruise
Yeah you should pay the $45 ($30 per annum and $15 once-off joining fee) and become an SAU:SA Club member Mike - we are having a Club dawn cruise and breakfast early in the New Year. Will be awesome, with tons of great cars in a nice relaxed group.
Nice purchase by the way! I have a black V35 coupe these days.
Sounds good, ill do that..
Black v35 hey, nice, im trying to get a mate to buy one of those.
have a good new years andrew and steve will definately catch up soon.
bzz350 Cheers for ya help..
cruise>?keen!!:rolleyes:
on a side note, went for a cruise up to mt gambier on the weekend, it seems they have no imports up there at all,,,,, the loals stop and stare at you.......and the locusts on the drive up are insane..
  • 1 month later...
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
