  • Replies 44
looking to have about 600hp at the wheels hopefully, dont know how much power loss ill have to the ground with an all wheel drive, anyone care to shed some light?
the t04z is rated to about 700+hp, but i dont want it to be too laggy, im after a balance of power and response maybe leaning a bit towards the power side, if it doesnt work out ill change to setup
As the TO4z is supposed to perform similar to a pair of GTRS's, it would be fairly safe to say it will start making boost below 2000 rpm, have a good .4 bar by 2500 and achieve full boost by 3800-4000. The right cams and head porting + tune will make this even more responsive.
  • 10 months later...
Hi Guys
I know its been like a year since ive posted anything... just wanted to let you know that things are still going ahead but just shitloads slower than i thought it would, ive been busy working and the engine builder has also had other commitments and hasnt quite finished it yet, he assures me it will be done within the next few months and i dont really want anyone else building this motor so all i can do is wait. I Spoke to him a week ago and he said the block and head is at the machine shop.
Ive boaght a set of TE37 SL among other things a week ago so i thought i would post that up
Hi Guys
Noticed you're in Perth, mind if I ask who is building the motor???
  • 3 weeks later...
+1
ill be watching this this is hopefully goin to be my next project
good luck with the build hopefully it will be finished soon
yeh the SL look really good pretty pleased with them, as for the drag car last time i seen it was at motorvation, its a 3.0 aswell but havnt seen it for a while now and i dont know the latest time
  • 5 months later...
still waiting on engine builder, he has been so busy with other stuff its annoying, spoke to him yesterday and he said all the machining was done and the head is complete, he basically has to put it all together and take it all apart again then put it all together again.
he builds these engines in his spare time, he basically told me he used to do it for a living but there's no money in it so he does it on the side, and he also looks after drag cars so if they break or need attention that goes to the top of his list
THAT is why this is taking so long ><
I have everything i need except for this motor so as soon as it arrives...
No money in it :mellow:
My mates engine builder (I thought you may have been getting him to do it, that's why I asked earlier) is absolutely rolling in it haha. Very very very busy though. Anyway, I understand how frustrating it is waiting on other people! Looking forward to seeing progress though :thumbsup:
Well either way he puts these engines together at his house, he still relies on his friends in the industry as he doesnt have the machines to do the jobs a workshop can, so they take time but also gets the work done at a very good price and still very proffesional
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
