Hi all,
Would it be OK to fill up the R34 GTT with 91 RON petrol and then treat it with Nylon Pro octane booster?
From the reviews Ive read, Nylon Pro is the bets one out there and raises the octane rating past 98 PULP.
Its just I can get access to 91 petrol but not 98... atm.
If that's all you can get where you are atm, then it'd be best to do just that.
Whatever your mean average RON is, sitting in your tank atm, the octane booster is only going to shift it up marginally.
You'll get a better result with toluene (ie methylbenzene), depending on what amount you put in; but through regular skin contact and inhalation, it's carcinogenic.
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5602755
if you got 98pulp in your tank and you drop in octane boost
how much more would it raise the pulp?
105pulp?
Doesn't quite work like that mate. As in theory adding more octane booster again would give you 111RON, then 118RON. Until you ended up with 300RON super fuel to run an engine with 37:1 compression...... laugh.gif
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5603658
Running Octane booster in general is a bad idea.
A once off is ok for emergencies... But then you can just stay off boost/light throttle and you'd be fine.
If you keep using it you'll run the chance of fouling plugs after a few tanks, and that'll make it just 10x worse over time than using proper fuel :)
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5604234
a mate of mine was a mechanic for repco a few years ago (the local repco store had a workshop on the side of it) and one day the nulon rep came through and had an octane test kit with him. my mate grabbed some BP ultimate out of his car and they ran a few tests. first they tested the fuel by itself. it was 98 octane (as you wuold expect). next they put in the standard measure of the pro strength octane booster (i think. this was about 5 years ago now so the memory is a bit dodgy). pretty sure this put it up to about 103 octane. then they put in double the normal dosage. the octane rating actually dropped back down to around 99 octane.
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5604477
just run it on 91, unless you have an aftermarket ecu tuned for 98 it wont be a problem. with a stock ecu your better off with 91 than 98 anyway.
if you use octane boost make sure you have plenty of cash for spark plugs, you'll be changing them every 2nd tank. not to mention o2 sensors and other shit like that
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5605357
are you missing that he said it was for a GTT, or are you taking the piss? the stock turbo ecu is tuned for minimum 95 octane fuel. running it on 91 octane will result in a loss of power, or if the knock sensors aren't working correctly a damaged motor. 95 or 98 octane will result it more power and safer knock levels.
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5605486
+1
Most people know that Australian 91RON unleaded is basically served as shots in Japanese bars... Our fuel sucks. Thus, imports not originally made for the Australian market should be run on 95 or better...
https://www.sau.com.au/forums/topic/348414-octane-booster/#findComment-5605679
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
