Update.
Diff sold
Gearbox sold
Tailshaft sold
Engine fan sold
Radiator mounts sold
Many parts deposits taken
Car is now at new location in workshop so much easier and quicker for me to strip and get parts shipped off. This also means all parts including rolling bits can be sold.
No name rose joint caster rods $150
Shortened upper control arms (have been lengthened they were too short) $150
Steering rack $100
Hicas lock bar $60
Alloy sub frame pineapples $60
Engine mounts $30
Front bar $120
HSD coil overs fully adjustable 16 step shock (might be type S) $550 all four
All aircon, glass, doors, handling parts, subframe, lights, and many bits still available so please feel free to make offers on anything.
Cheers,
Daniel
Radiator Sold
Lots of stuff here,
Lightly faded back seat good condition $50
Malpassi Adjustable EFI Fuel Pressure Regulator $90
Bonnet $120
Boot $90
Doors $100 each
Door trims $55 each (drivers sold)
Steering rack $100
Power steering pump $60
Larger alternator and cut bracket to make it fit $100
Front bar with reo $120
Disc to disc Sub frame (minus diff, hicas, coilovers) $250
Need to get parts moving or it will be sent to the wreckers.
C pillars sold sorry. Make an offer on any or all aircon parts, thanks
Hey mate,
Would you still have the trim and boot for the gearstick, if you do are you willing to ship? Keen as FK as ive been chasing one of these for over 9 months now
Cheers,
Brenton
PM's replied thanks people. Starting to move quicker now, anyone want a shell with many spares? Thinking $2000, has all doors, dash, carpet, glass, electrics, lights, boot bonnet, complet brakes R33 GTR fronts, hydro handbrake, wipers, wheels with good tread, half shafts and most of suspension, subframe, battery (boot mounted), some trims, probably more that I haven't remembered...
Yes I have stereo brakets, $25
I have got the complete center consol but it's been in a shed since I got the car so needs a good clean $35
HSD coil overs Sold
Got front and back strut braces $90 front, $70 rear.
And surprisingly I still have very good condition full amber indicaters, the ones that make your donk sexc!
if he does not get the radio brackets i will get them as i need them and the centre consol if you have that i will get that to
just send me a picture of the items 1st just to make sure there correct
can be via MMS or what ever
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
    • *waits* for chop idle videos and TT kit hanging off the motor. I like these sounds now, my inner bogan is growing.
    • Want to buy a good running Rb20det in Sydney preferably complete or long block
