Here is a quick DIY on how to fit the PSI Parts carbon fibre foglight/indicator covers that I organised to get made in this group buy:
http://www.skylinesaustralia.com/forums/topic/337956-carbon-fibre-s2-front-foglightindicator-surrounds-group-buy/
The install is very easy and only requires basic tools and basic mechanical skill.
TOOLS REQUIRED
12mm spanner
Philips head screwdriver
Flat head screwdriver
First of all use a 12mm spanner to remove the two bolts that hold the entire housings onto the front bumper:
You will find the two bolts located in these positions:
You will need to remove it out at an angle because there is a clip on the outside that holds it in place and also remove the electrical plug.
There is 6 screws that hold the cover onto the housing, remove these screws:
Now simply remove the cover and put the new carbon covers on (with one of my covers I found that the factory screws were a bit to thin to be used on the new covers so I simply purchased some slightly thicker ones). If the screws don't perfectly line up with the mounts, just use a flathead screwdriver to gently push them into position. They shouldn't need much of an adjustment though:
Put it all back together in the reverse process and you are done :)
I'm very happy with how they turned out and the fitment is virtually perfect. The carbon weave is gorgeous and it definetely gives a unique look to the series II factory front bumper.
Cheers
Phil
  • Like 2
  • 4 months later...
freaking sweet!! every time i see your car it has more tastfully placed carbon :) top notch.
main thing ive been looking at doing is replacing the orange lenses with some clear ones and orange bulbs. would make it look even smoother. but the design of the two peices makes it alot more work than it should be considering theyre the same diameter :(
*just read the group buy thread. seems like you guys beat me too it :)
still got the spare set of carbon surrounds??
Edited by boiracer
  • 11 months later...
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
