Re Materializing
I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake. -
Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system. -
By sausagepianist · Posted
Thanks for that Paul. Do you think if I posted a picture you'd be able to remember where it went?
