woah thats crazy i feel for truckies as 8 times out of 10 they are not in the wrong when accidents occur. people need to realize how much weight these things carry and if you stop right in front of it you have the best bit of 70 tonnes running you over. not much is going to be left of anything after that bull dozers you.
I recently drove to Melbourne to pick up my new GTR and I saw a lot of crazy driving like this. I was surprised at how many people were driving in emergency lanes like in the video.
4.30 why should she back up she was there first, just saying.
no sympathy for truck drivers im sorry the shit i see them do is 11bty times worse than what this vid shows. Good to see the truck drivers have the same amount of curtousy for each other as they do no car drivers - none.
Coz she was on the wrong side of the road blocking oncoming traffic.
I drive througfh there quite often in my truck, you'd be surprised how many people do this. At least they have the courtesy to get out of the way....
I see this type of idiocy every day, you learn to accept it and not worth the trouble most of the time...
Cab drivers are the best though, especially when someone puts their hand up on the footpath, cabbie comes in from the right lane pit stop styles!!!! Have come close to taking a few out over the years....
Yeah i know.
I had been waiting to pull out for about 15 mins that 10 other cars and trucks behind me as well got really mad and pulled out.
i know its gonna sound like bs but honestly didnt see the other truck tailgating the one turning.
But what the hell its past now and i learned from seeing it on the internet that i need to chill and relax and wait for the right moment or you get your stupid acts posted so everyone can see.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
