I got a R33 antenna switch
wanted to make antenna switch that will turn off the antenna from going up when the deck is on
on the back off the switch these 3 pins
Does anyone know what the 3 pins are in order
Does the r33 antenna switch light up?
I will post a picture of the switch soon
https://www.sau.com.au/forums/topic/348539-r33-antenna-switch/
dinna
either put another switch onto the centre wire ( the one from the deck)
or
if its a Series 2 then the 2 outside wires put the ant up half or full. ID the 'half' wire and cut, then use that as the off
or
I beleive the antenna comeing out the rear guard is for AM anyway and the one on the top of the back window is FM, so I've unpluged the antenna motor(@ the back)
that way the ant stays down and don't seem to affect reception
