Hey guys, Recently I just got a new job, and my employer has told me that I'll have to do a 'medical'. I havn't been able to contact them since, as it's been holidays.
Having never done one before, what would it entail? Height, weight, eye test, lung capacity etc?
More specifically would it involve a drug test of some sort? I'm not into the illegal stuff, just wanting to know what I would be faced with.
Also what are the legalities regarding said testing? Got into a discussion with my friends and they seem to be under the impression that they have to notify me if it involves a drug test or not, but I need some more advice. I'm assuming it's just for legal and insurance purposes?
Any experiences appreciated.
Thanks.
{edit} The job is for a luxury car dealership in Ossy Park, working in spare parts.
Edited by turbo x-trail
https://www.sau.com.au/forums/topic/348588-workplace-medical-for-new-job/
  • Replies 44
depends. A alot of places like CarePoint offer pre employment medicals as a package deal, and there are differing levels. If the job is mines or refinery based a drug/alcoholtest, mines health test (lung capacity and hearing test) are in the default list, but as its not mines they might have opted for a cheaper level of testing and just want to make sure you are not going to claim back/leg injuries within the first 6 months.
And no, AFAIK they are not required to warn you of drug/alcohol tests (been on a few sites myself where you get no warning, just a tap on the shoulder). You always have the option of refusing these tests (ie, NO ONE can force you to take a drug or alcohol test against your will uinless its the police for traffic reasons) but a refusal to take the test is almost always viewed in the same way as a positive result...
pretty sure it does include a drug screen. so stay off the hash for a while
Thanks.
Not sure if it's done through Care point or Prime I'll have to check with the employer to be 100% I guess.
I used to work for health for industry.. The test consists of a questionnaire which you would be best to answer correctly.. Also a general fitness test may be involved depending on the job
But you also get lung capacity and stuff like that, they may or may not request a drug test, they'll let u no beforehand etc... And the results can only be disclosed with your consent, contrary to popular belief not that many companies do drug testing
including your weiner, i had some work experience girl watch me piss, was real awkward. I work on a minesite and the medicals include drug test, and we can also get tested walking through the gate. Go to your local hydroponics shop and get that flushing liquid if your that worried
except almost all of the "flushing" agents include a masking agent that sets off alarm bells with pretty much all of the testing protocols used currently.
Yeah all good advice, but I doubt it'd even be a problem at all judging by my lack of "exposure" to old mate mary of late. I'm still just wondering if the job itself will need a drug test included with the medical. I've done my reading, and plain and simple old water flushing out your system coupled with vitamin B and iron does a good job of reducing your urine's pH levels and content. THC is stored in fat cells, so aerobic exercise also helps apparently...
NO EXCERCISE FOR A DAY BEFORE THE TEST
Yes, THC bonds to your fat cells but it is only released when you burn those fat cells.
No strenuous excercise for a day or two before the test, particularly on the morning of the test. Also a good idea to have a steak for breakfast on the morning of the test as the iron and proteins will help.. especially if you are flushing yourself with shitloads of water as they can tell that.
Edited by bubba
Sweet thanks bubba. Judging by the amount that I've been sweating lately (it's been humid as balls in Perth ATM), and given that it's been two weeks since the last pufferoo, I don't think there's gonna be a drama. Plus, im a fairly lean sorta dude and I have a crazy fast metabolism...
Confirmed from my employer that there is indeed a test, done through prime next week so there ya go!
No worries and good luck!
P.S. I've got a mate who blew the test out of the water.. the maximum acceptable amount is 50ppm but he scored so high they had to use another machine (the first machine only read to 500ppm) and he came in at 1950ppm
That is the current record if anyone wants to attempt to beat it :P
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
