BNIB(Brand new in Box)GReddy Type-S Performance Damper Coilovers
--Manufacturer's Blurb--
Designed for the optimum balance of traction, comfort, and adjustability, GReddy Type-S suspension kits offer the finest features like: large 46mm dia. pistons in a Mono-tube shock, 32 way adjustable damping, adjustable base and spring perches, thick billet upper mounts, and a lightweight coil springs. Instead of the common heavy spring rates, that offer harsh rides and easily loose traction on bumpy Australian roads, Type-S systems utilize a relatively softer spring with a longer stroke to maximize traction on the streets and track. An added benefit of this is also a comfortable ride for the street. Applications available for many popular Japanese vehicles.
Four Corner, Full Length Adjustable Ride Height
With an adjustable threaded base and spring perch height adjustments can be made without sacrificing spring preload or shock stroke. Even with a lower ride height, by maintaining stroke, bottoming out can be prevented, thus maintaining traction even when hitting a dip while corning. In addition, by having both adjustments for the front and rear, it is possible to adjust ride height in millimeter increments if desired.
Adjustable Spherical Bearing Upper Mounts
(pillow-ball) Standard equipment on vehicles equipped with front struts are adjustable spherical bearing upper mounts. The thick 10mm aluminum upper plates are precisely marked for secure and accurate camber adjustments. While the use of replaceable spherical bearings add extended life and cost effectiveness to the system.
Mono Tube Shock Design
The use of a large 46mm diameter piston in a Mono-tube shock design provides quick reacting dampening, even during low speed driving. While, the construction of the case is not only lightweight, but also designed to be very rigid.
Strengthened Rubber Bushing Upper Mounts & Billet Aluminum Brackets
For non-strut type applications, a thick 33mm strengthened rubber bushings on sturdy 10mm billet aluminum upper mount and lightweight billet aluminum brackets are used. This offers both exceptional noise reduction and very controllable handling profile.
Lightweight High-grade Coil Springs
All systems employ a special high strength steel (SAE9254) in it’s coil spring. This allows the springs to have the optimum balance of precise stroke, durability and lightweight. Rear springs are designed with 250mm (unless listed otherwise) variable springs to maximize the rebound stroke. This inhibits loosing traction when "lifting" while cornering. It also contributes to stable traction in wet or dry road conditions.
Extended Adjustment Cable
For applications with the rear shocks mounted beneath a rear deck lid (speaker board), an extended adjustment cable is included. This allows for easy dampening adjustments without having to remove components. All that is necessary, is creating a small 6.5mm hole for the tool.
  • Suit S13/180/A31
  • Height Adjustable
  • Damper Control
  • Original Dustboots
  • Springrate is 8-6
$1800
Used Silk Road Coilovers (possibly RM/A8 they look similar)
Extremely high-quality, high performance coilover systems for the most popular Japanese sport compact applications. High pressure, gas-charging, mono tube type shock absorber. Extra-thick piston rod design, coupled with innovative valving, allows a perfect balance between capable high-speed damping and low frequency smoothness. Also minimizes aeration and cavitation, even under extreme conditions.
  • Suit S13/180/A31
  • Height Adjustable
  • Damper Selection
  • Springrate is unconfirmed website states 8-6
$600
Used Recaros Red/Black with Seat Rails - Still Supportive and Solid but suit re-upholstery
Drivers side:
Front:
Right:
Left:
Passenger:
Front:
Right:
Left:
  • Comes with rails to Suit R32 / A31
  • Suitable for reupholstery
  • Universal Seats, can be used on either side with suitable rails.
  • Genuine
$600 for pair with Rails
Contact Details:
PM me
Email: [email protected] (email checked regularly)
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
