BNIB(Brand new in Box)GReddy Type-S Performance Damper Coilovers
--Manufacturer's Blurb--
Designed for the optimum balance of traction, comfort, and adjustability, GReddy Type-S suspension kits offer the finest features like: large 46mm dia. pistons in a Mono-tube shock, 32 way adjustable damping, adjustable base and spring perches, thick billet upper mounts, and a lightweight coil springs. Instead of the common heavy spring rates, that offer harsh rides and easily loose traction on bumpy Australian roads, Type-S systems utilize a relatively softer spring with a longer stroke to maximize traction on the streets and track. An added benefit of this is also a comfortable ride for the street. Applications available for many popular Japanese vehicles.
Four Corner, Full Length Adjustable Ride Height
With an adjustable threaded base and spring perch height adjustments can be made without sacrificing spring preload or shock stroke. Even with a lower ride height, by maintaining stroke, bottoming out can be prevented, thus maintaining traction even when hitting a dip while corning. In addition, by having both adjustments for the front and rear, it is possible to adjust ride height in millimeter increments if desired.
Adjustable Spherical Bearing Upper Mounts
(pillow-ball) Standard equipment on vehicles equipped with front struts are adjustable spherical bearing upper mounts. The thick 10mm aluminum upper plates are precisely marked for secure and accurate camber adjustments. While the use of replaceable spherical bearings add extended life and cost effectiveness to the system.
Mono Tube Shock Design
The use of a large 46mm diameter piston in a Mono-tube shock design provides quick reacting dampening, even during low speed driving. While, the construction of the case is not only lightweight, but also designed to be very rigid.
Strengthened Rubber Bushing Upper Mounts & Billet Aluminum Brackets
For non-strut type applications, a thick 33mm strengthened rubber bushings on sturdy 10mm billet aluminum upper mount and lightweight billet aluminum brackets are used. This offers both exceptional noise reduction and very controllable handling profile.
Lightweight High-grade Coil Springs
All systems employ a special high strength steel (SAE9254) in it’s coil spring. This allows the springs to have the optimum balance of precise stroke, durability and lightweight. Rear springs are designed with 250mm (unless listed otherwise) variable springs to maximize the rebound stroke. This inhibits loosing traction when "lifting" while cornering. It also contributes to stable traction in wet or dry road conditions.
Extended Adjustment Cable
For applications with the rear shocks mounted beneath a rear deck lid (speaker board), an extended adjustment cable is included. This allows for easy dampening adjustments without having to remove components. All that is necessary, is creating a small 6.5mm hole for the tool.
  • Suit S13/180/A31
  • Height Adjustable
  • Damper Control
  • Original Dustboots
  • Springrate is 8-6
$1800
Used Silk Road Coilovers (possibly RM/A8 they look similar)
Extremely high-quality, high performance coilover systems for the most popular Japanese sport compact applications. High pressure, gas-charging, mono tube type shock absorber. Extra-thick piston rod design, coupled with innovative valving, allows a perfect balance between capable high-speed damping and low frequency smoothness. Also minimizes aeration and cavitation, even under extreme conditions.
  • Suit S13/180/A31
  • Height Adjustable
  • Damper Selection
  • Springrate is unconfirmed website states 8-6
$600
Used Recaros Red/Black with Seat Rails - Still Supportive and Solid but suit re-upholstery
Drivers side:
Front:
Right:
Left:
Passenger:
Front:
Right:
Left:
  • Comes with rails to Suit R32 / A31
  • Suitable for reupholstery
  • Universal Seats, can be used on either side with suitable rails.
  • Genuine
$600 for pair with Rails
Contact Details:
PM me
Email: [email protected] (email checked regularly)
