White 96' R33 GTST, immaculate condition in and out no dents or scratches!
96,500km's
Manual
Turbosmart dual stage boost controller (hi-lo)
APEXi S-AFC II air fuel controller
Full HKS Superdragger exhaust, 3.5" mandrel bent with high flow cat
Blitz BOV
Heavy Duty Brass Button Clutch
HKS Type 0 turbo timer, displays volts etc.
Autometer Boost guage mounted on A pillar
Dual Stage shift light
Nismo Gear Knob
HKS Pod Filter
Short Shift Kit
Strut brace
Red VHT sprayed Calipers
Koni height and damper adjustable suspension with King Spring low's
17" BSA Racing rims 235/45's all round, brand new Dunlop Leman's tyres on front
Full central locking and 3 point imobiliser alarm
Dual airbags
Hicas 4 wheel steer and ABS brakes
Extra's: Tommy Kaira Wing sprayed same colour as car, White faced colour changing EL dials and blue axs seat covers.
$24,900 firm contact via email [email protected] or pm me.
Pics will be up tommorow as i dont have the digi cam tonight.
    • Don't turn down the limit yet. Put a mechanical pressure gauge on the car in the same spot and go and prove it.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
