I know, for me music is as good as manditory when driving. I'm lucky my trip to work is only 15min, if it was like an hour i think I'd go crazy. I already find myself humming along with the tone of the exhaust note lol
haha thats not as bad as me.
when i crashed one of my S15s i was driving a FWD pintara, i was making turbo and BOV sounds when i was driving it. no, the radio also didnt work in that car :(
No mate, sadly my finances don't run to Brembo's unfortunately, but I think the R33GTSt calipers teamed with this;
http://www.conceptzp...40203.166.28.81
I should have more than enough brake power.:thumbsup:
yup thats the kit Ive got on the front of my S1 stag
r32 gtst calipers tho for me
Interested to hear how you get on with these brackets. I have tried several on my C34 without being able to fit them (very different from Skylines) although I see you have an M35 - lets hope they are the same as 350Z.
mate no worries with the brackets, fit fine on my S1
also the bracket set from revolution brakes Wilwood superlite 4-pot / 324mm discs fit fine too !
Fitted a brand new bright red Recaro millinium to the drivers side. passenger side can wait to see if I like the fit.
Picked up a pair of new Drift seats (r34 GTR copies) today as well in black
Cleaned up the the EVO 8 recaros as well today
Need to decide which seats to use.
Also looking at some new Bride Euro II as well later this week. similar to GTR
Measured up some new 6 pot 355mm brakes today for the front to see if they will fit behind the 19" GT-c's
Today i chucked in some splitfires because three of the stockers were missing at high revs in third gear.
I also installed an AVH-3200BT double din reciever awesome unit for the price, now i've just gotta find time to put the amp in!
Put some Works Meisters on...
Very nice man, surprisingly good actually!
You got that cooler in yet?
nice!!!
now you just need aero side skirts and rear bar to match the front bar :)
LOL... maybe you need to drop a less subtle hint!
Thanks for the positive comments fellas.
I never thought my front bar was anything other than stock standard. What do the Aero sides and rear bar look like?
Haven't got the cooler in yet, but that's going in once the car's out of the bodyshop.
That, and a tune are my main priorities because the car won't rev beyond 2300rpm right now sad.gif
A tune wont help you, sounds like the afm is cactus. What are the symtoms, do you have an engine light?
Don't pay people to fix these barges whatever you do. They will take you for a ride every time as they most likely have no idea when it comes to fault finding M35's. Use the good SAU resource, us blokes, and fix it yourself. :thumbsup:
  • Like 1
Can I have a stab and say limp mode from a stuffed AFM?
Gotta play the odds :P
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
