Ripped Aaron's turbo out, 2 hours flat. Not bad going.
He is going for a bush core this time as bearings have left a bad taste in his exhaust, and bits of wheel. Shaft snapped in half.
Don't want to sound sceptical, but can you prove the increase in driveability, economy and reduction of intake temps?
This argument has been done to death.:whistling:
Back to back, same day, plenum skin temp measured with a non contact temp gun (accurate to 800deg) 31deg reduction.
Economy; only .1-.2 km/l, possibly a bit more.
Driveability; VERY subjective, because it's a "seat of the pants thing". But; Yes, farking HEAPS! Better response, stacks more torque.
DUDE! i have to give scott the biggest props for doing this!! had the turbo out in 2 hours! and managed to get it fixed under warranty..
stage 2 wheels bush bearing core!
cant wait now.
8psi. lol. Not even tuned, second gear apparently at 2000 revs. The bearings were noisy when it first went in, after 3 months it had snapped the shaft and demolished the exhaust wheel, front looked pretty good considering but it was seized.
I had the car on stands, its an easy job if there is no heat-shield so guess what's not going back on. lol. 3m stick-on heat-shield will do the job nicely. :thumbsup:
yeh 2nd gear at about 2k revs. i was behind someone going slow so i wasnt even pushing it.. i mean it was 6am.. i was tired. then bang black smoke. that woke me up good.
hasnt been in the car for even half a year..
n yeh ive turned the boost right down as it wasnt tuned yet..
I don't really want to dob the shop in as he is looking after us with a warranty, it was a ball bearing highflow though.
Due to the damage to the housings it looks like he is going bigger than mine.
Nice, how do you plan to get it running?
I still think its a downgrade unless you go forged internals...
You are suffocating the engine if that has the stock turbo on it. You will be on boost at idle. lol.
The engine will be built, and it will run a bigger turbo.
Firstly though, I need to sort out the EMS and get a manual conversion happening. My tuner tried on the Haltech and said it isn't compatible, something to do with the pulses, I forget what exactly.
Has anyone made any headway in manual conversions for the M35?
Is the R34 GTR gearbox with bellhousing modifications the go?
Im about to go down this path myself but I think I will hold off on my 3.5 build for now for the very reason you are having now, people dont understand these engines. You will have to go standalone, PS2000 or motec m800 or similar which means you may not have the dash, attessa abs etc. Will you be paying a mechanic to learn all about this engine?
Pulses? I guess he means the crank sensor? Better find a new tuner... What Haltech was he using anyway?
What prompted this change over? Did you damage your engine? Do you still have it?
lol... you don't sound sceptical at all!
Point taken. I have just been on a few forums where people fit stuff, then say how good it is without hard data. I can't really 'feel' your 'seat of the pants' performance upgrade.
Just want numbers that's all.
Thanks Daleo.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
