Same size motor as a m35 stag. 2.5lt V6 but this ones a 2 stroke.
puts out more power tho its good for 200hp and about 80-85mph on a calm day. :nyaanyaa:
Edited by Big Fella
Was it hard? Fitting mine tomorrow lol any tips?
It wasn't too bad. The only problem I had was I thought the lines that came with the kit were a little short for my liking. However, still more accessable than what the oil filter was before.
I also had to cut down a brand new Stanley 300mm adjustable spanner to fit under the intake plenum. It is now more around 120mm :laugh:
Rhet fuel filter has 6mm bolt,
You need more then that mate,
put filter down so you don`t pour Oil everywhere ,
plastic bag :stupid:
if your still worried PAPER BAG TOO :thumbsup::cheers: ,
what size lines are you using ?
are you boys still using 2 filter as thats a SMALL FILTER
Got nistune done to the car today. Pretty happy with power gain, was 135kW before the nistune. Very smooth delivery!
Excuse my C34 ignorance but shouldn't you be getting more torque? Power looks great! Just was expecting a different torque curve...
Was thinking the same thing when I saw it!...Hp figure is good...the nm figure does not make sence.
Wouldn't have a clue! I got Shaun to tune for economy for what it's worth. Apart for a smooth curve I'm not sure what's what on the print out.
That's a pretty impressive gain. Was it just the tune or have you also added bigger exhaust, more boost or any other mods? Good advertisement for Nistune. - OK just saw your other post - now for an upgraded turbo!
Yeah just Nistune. If this also translate to better economy it's be great!
Edited by webng
Finally the Stageas coilovers turned up..
Rears are in! oh what a feeeeling.. should have done this ages ago..
fronts going in today!
And then maybe do the Emo ones too if i can be bothered today..
Installed New Alternator and Power Steering belts today.
Also adjusted the front sway bar to a stiffer setting now that I have some tires with a little grip. :)
Diagnosed another problem of a big hesitation around right hand corners.. time to replace the Walbro fuel pump. :(
Whats wrong with the fuel pump mate? Did you end up running full voltage to it? If its in the stock housing it shouldnt cut out at all as it sits in a cup in the tank, is it when low on fuel or all the time?
No, Stock power supply.
When I drive around right hand corners and I give the car a bit of throttle (usuall in 1st or 2nd) I get a big hesitation around 3-4k rpm. The car settles and then continues on to higher rpm.
I took Craig for a drive and he thought it felt like the fuel pump as he though his did something similar before it failed.
Not sure if it is all the time but I am usually conscious of it when the tank is 1/4 or lower.
I have the option of changing the pump tomorrow whilst fuel is low of filling up tomorrow and seeing if it still persists with a full tank.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
