First thing I learnt in intro to law... you enter into a sale contract and thats it. He would have been pissed if you backed out. If he accepted payment thats accepting the sale contract. He can't just back out like that, but you're hardly going to take him to court over $150 worth of calipers...
I didn't win those other calipers either, so I'm keen on your mates calipers Big Fella!
How much are the seal kits? I saw a set of all four on eBay for about $200, which seemed insane to me just for the seals.
Hoping I might be able to pick them up from Big Fella, or a skyline owner on here upgradng (and maybe even get some second hand discs).
Get your money back for the others?
yeh there about $100 for fronts
rear calipers dont fit on our car so try asking if you can split em up..
yeh got money back.. should be picking the other ones up tomorrow or monday..
craig will.
give craig anything unbreakable and guess what? he'll break it
lol...yup!!!
you guy's looked around for R33GTR stuff yet?...might find them cheaper than Z33/V35 stuff!....front's only!
Just quietly Cam....big f#$king difference between a 20year old cross drilled rotor and a late model Porshe rotors and ceramic Ferrari stuff mate! Every time I have had crossdrilled rotor's on a car(any car) they have eventually cracked!
Edited by Jetwreck
You talking calipers? I've found R32 GTR calipers are cheaper than R33 GTSt. I didn't know R33 GTR fit?
The cost of a rebuilt set of R32 GTR calipers, decent slotted discs and decent pads had me looking at v35/350z stuff, but thats just dearer again!
Yeh callipers and rotors from a R33GTR.......they are basically the same calliper as the Z33/V35 brembo just black.....rotor is 324mm instead of 284 like the r32......will bolt up the same way as the R32's as well.....I know this as I started with the R32gtr calliper and rotors and just recently went to the R33GTR stuff.
Well u coulda told me that before I picked up my gtr32 calipers today.
Meh I don't think it matters, the way scotts was stopping was f**kin insane! I don't think I'll need more than that.. I'm not looking at track work anyway..
The ones I picked up look good.. The seals look new still!
So I'll need a caliper adaptor then?
The washer? Yeah I read Craigs instructions in M35Stagea.info, but he said R33 rotors were 324mm, and R32 rotors were 284, so I'd need that caliper bracket I think? This is the first I'd heard of R33 GTR calipers fitting?
Do they fit over standard wheels? I've still got standard 17" RS wheels.
Oh screw that I'm not going through that much trouble for a couple of mm. If that much trouble is needed, but he said they are the same as 350z brembos so maybe no adaptors.. Just the sleeve washer thing
Craigs Brain and possiblily other parts of him are on holiday ATM.
R32 GTR dicss are 296mmx32mm with Sumitomo calipers (same diameter as stock, the difference is in the width) Not 284mm
The R33 GTR are 324mmx30mm- With the Brembo calipers.
What you need to make them fit- the difference is in the bolts - R32 /33 being 12mm, and R34/M35/Z33 being 14mm (I think :blush:)
A little Sleeve that goes on the bolt to fill that gap is whats needed.
Scott might just jump in here (he turned mine up):thumbsup:
Edited by PN-Mad
R32 GTR, non brembo is 296mm x 32mm. R32 GTSt is 280mm x 28mm. The reducing sleeve for the mounting bolts is all you'll need.
Edit; Alex beat me to it.
Edited by Daleo
Scott might just in here (he turned mine up):thumbsup:
But wouldn't I need an adaptor to move the caliper to accept the bigger R33 GTR disc?
Does that make R34s bolt on too?
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
