Yeah agree, but it was just timing, nothing complex! Thats my excuse and I'm sticking to it!
Off to buy an Emanage then... any suggestions where?
Is there anyone in SA who can tune an Emanage?
The place where I got it from (ebay store) was located in Japan, I'm pretty sure I got the EMU + harness for around $600/650 delivered.
Unfortunately they were affected by the Tsunami and they don't seem to sell EMU's anymore...
Love ebay sometimes.
Emanage Ultimate: http://cgi.ebay.com....e=STRK:MEWAX:IT
Universal Harness: http://cgi.ebay.com....=item588275acd9
MAP Sensor: http://cgi.ebay.com....=item27b7e1a13d
(Did see this cheaper sensor, but looks dodgy as! http://cgi.ebay.com....=item230fca0ec0)
Think thats it for an Emanage install?
Oh, and Informeter: http://cgi.ebay.com....e=STRK:MEWAX:IT
Sounds like it might be a useful acquisition?
dont get the dodgy ones. if they arent an accurate reading, your fuel map can go right out..
Informeters a good doo hicky..although its not really important. you can get another boost sensor and wideband into it. it will tell you your water/intake temp.. throttle % speed RPm.. but the injector duty sycle n some other stuff will be incorrect as a tune will change figures.
they only had two ECU'I bought one, then you bought one.. i tried messaging him about the profec B, but paypal sent me money back. i think his shop was destroyed in the tsunami. poor guy!
map sensor is needed the way i see it. its the safest way as your Tuner isn't simply guessing. hes calculating figures!
when you look for injectors, ask for the plugs. you will need to cut the stock connectors off and solder the new ones on. I'm using Seimens Deka 610CC and im about 80% duty with e85. work fine and dont miss a beat. they are a 4 squirter!
A wide band will help for road tuning, but the dyno should have one for the dyno....i guess if you want one..
i pulled my turbo out again, to open the wastegate up.
took me 2 n abit hours.. proud much??
opened up the wastegate. put everything back together. and no change. what a waste of a day.. looks like the actuator may be playing up :(
What was the car doing that made you think something was going on with the wastegate?
I ordered an Informeter. That way I don't have to guess whats going on and worry unnecessarily.
Probably do FMIC next. Still deciding whether to do fuel system before emanage or vice versa. Coming along nicely! :thumbsup:
You'll have to come by and do mine soon Aaron :P
lol i told scott that you needed this done.. he laughed hahah
its over boosting. would hold 15psi through to about 4500rpm and then shoot up to 22psi. felt as if the Wastegate was too small and as the exhaust air flow increases it cant push any more through the gate and comes out the fan again, only to continue boosting. I opened up the wastegate as much as i could. and no change.. looks like the actuator isnt allowing the gate to open enough...
lol if anything the informeter will make you worry more when you start seeing figures.. trust me, its why Craig got rid of his lol
Got it back from panel and paint... All new again.. Insurance company sent me a brand new wheel instead of repairing old one and bruce from mag and turbo gave me a tire to use till I save up for a new set! LEgend!
So today I pick up and fitted a black bonnet, was easy enough to change over just not to sure if its what I want anymore. Maybe after a few weeks I'll decide if I'm gonna keep it on or change it back.
What you think?
yeah was thinking roof, mirrors and the little bit behind the rear side windows need more black.
Then maybe I'll change the chrome stripping to black, then black out the headlights and foggies, tint the rear lights hmmm where to stop?
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
