Yes that's right . Gonna post some photo's online to show the workmanship.
Once again thanks to Craig and Andy for the setup. Nice work
finally ordered a 3" hi flow metal cat for the stagea, decided to go with the 100cpsi, that way the SA boys won't miss out on the campfire action on gear changeswhistling.gif
Got my car back with new clutch and re-dynoed
Looks like my GT3076R has shit itself at 18,000km old
Fun job of removing it tomorrow to inspect.
Man that sucks. Did it let go on the dyno?
Edit: never mind, just got your pm...
Edited by QWK32
No ALL good
The turbo was loose on the manifold. I went to start removing it and all 4 bolts where finger tight :blink:
Just put it back togather and took for a drive. A little greasy on road = a bit sideways in 2nd (AWD)
Love the new tune, only 20 more hp peak but and extra 45hp thru the midrange. What a difference
Drag day next Saturday.
Nice video craig where you testing the drive in motion for the Xanavi at that speed. What did the leaf look like. Pity the 34 wasnt in front would of been nice to hear your car a bit more at the end.
Sold my beauty yesterday. Didn't take long once the new pics went up. Car sold itself in person. Car is going to Adelaide. New owner is a genuine bloke and will look after it I'm sure which is the most important thing! The only question now is - what next!?
happy!!!
Well down pulling her up into the final corner... its always a tough one to judge how fast to go in.... I always want to keep pushing along that back straight and then i have to deal with the wall on the exit!!!
what top speed did you get down main straight how did she handle the kink before turn 1???
My old 4AGTE AE92 corolla used to get 180 down the straight farrkkk it was brutal through the kink but.... praying i could keep her straight to so i could drop anchor for turn 1 made me think some cars are just not designed for the track...
did you get a time recorded at all?? would like to know how it compares to other cars..
congrats!! or should i say sorry to hear??
you should turn a M35 into a masterpiece aswell.... since you did such a good job with yours..thumbsup.gifthumbsup.gif
got off the clock going down the straight....which was enough to pickup and go around some cars.....wasn't really looking at lap times as would not have wanted to depress myself with the Nankang(hangkang!!) goodness.
But I was doing 1:05's in the R32 with old tyres and no boost on it's first shakedown since the rebuild.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
