1:05 is a very good time.. my mates PRB only gets around that time.. i was getting 1:12s in the corolla.. that definitely surprised a few ppl..
yeh...was not bad except I had no idea I was going that quick as I was only cruising around for the shakedown before Lakeside.....I have enough confidence to say that the car and myself are capable of cracking into a 1 minute flat and possible a 59(my target). Shows how much of a difference there is between the HR31 of which I cracked a 1.04.4 and the R32....GMS knows how to build a car that's for sure!
Those PBR's are awesome BTW!... fav car around that track though would be a EVO with good aero and a straight cut GB!
59s would have to be some sort of record... yeah the old PRB goes pretty hard considering its only got a silvertop 20 valve 4AGE.. its had a lot of race history though and the suspension is very well sorted.. previous owner took about 10 sets of suspension to wakefield and had a day of running it and changing it till he found the right combo of spring rates... (my mate just needs to learn how to drive better!!) it was one of the first built with the aircraft honeycomb aluminium.. heres a pic..
yeah when im back in sydney i will be in the market for an EVO 7.. since i now no longer own the M35..
This weekend I helped Chris (Spoolin) re-set his suspension and fit some aggressive 19 x 9.5 +22 CE28 style wheels and tyres to his M35.
It looks so tough! it did require some guard rolling, but the offset is pretty aggressive for an M35.
I'm looking at the same rims for my rig, how much they poke out???
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
