got my remsa pads on my desk (apparently between the qfm hpx and ar1m but still low rotor wear and dust)
i really want to put them in tmrw but i also want to machine the front rotors :(
really wishing i was either in qld (my mate has lathes and stuff) or had a big lathe in my garage
I have a lathe the disks fit onto Tom but I could never hold them in the chuck well enough to face them properly, they need to be bolted/clamped in. My local bloke machines disks for $20 each anyway so I don't bother.
I have a set of Brembo's I am rebuilding at the moment, new seals etc. When he machined the Brembo disks he had to change to a carbide cutter as they were so hard. Pita for him apparently.
Dropped in on Thursday; to see the bars in primer, looking slick as, waiting for paint!woot.gif
Hopefully they'll be on by the weekend!
The bolts that mount the sides of the rear bar (top edge) are these accessed from the boot? What trim do I need to remove to access them?
yeah i think jap rotors > australian rotors
we did a pair of 31 rear rotors at my mates workshop over summer and they went well (any the calliper had locked on so the surface was blue = hard) and it took the surface off well, it just takes a long time to set them up and make sure they are true plus most lathes won't reach and do both sides without flipping the rotor around
so if you have to pay someone to run them on a regular lathe = exxy because its time consuming, but if you free lathing (like i do at uni banana.gif) then its kinda worth it
yes
just the inside trim each side. dont lose any of the nuts, i dont have 100s of them spare lol
yes
Thanks Iain :thumbsup: Man, I need to tee up with you to pick up that arm too; totally forgot about it! You about one night this week?
Cheers, Dale.
took off the stock airbox apart, washed and cleaned the top front part (lots of dirt and gunk in there for some reason), took off part of the resonator (broke a couple of clips in the process pinch.gif), took the car out and the engine sounds louder, but wanted a bit more loud, any suggestions other than changing to pod filter?
if your wanting abit more loud without tuning, i wouldnt do this.
you would need an eManage as you'll be hitting airflow cut quite often
agree with aaron...not planning to get any piggyback ecu or anything, just want a cheap way to make the intake sound louder without using pod filter...
what about the part underneath the panel filter? can i block it somehow?
If you want more noise you can leave the top off the airbox - down side is warmer intake temps. Your choice - more noise or better performance. If you block off the bottom of the airbox the car probably won't go at all.
Hey Chris whats wheels are they? Mate of mine asked and I assumed XD9's at quick glance but they are indeed different, not to mention they don't make XD9's in 19"...
They are a CE28 copy by a company called Varrstoen.
CE28! I forgot about them. Are they quality copies? I've been living in a carless world in the mountains of Canada for the last year and a bit - amazing how much has changed in the mean time lol.
Varrstoen probably make one of the nicest copies going around... They actually make wheels is good size/width and offsets unlike most Chinese wheels which haven't much selection at all.
Mike
Yeah I was keen on WedsSport SA-67R's for my M35 until I realised that I'd either be cramming a 10" wheel onto my car or run a 9" wheel with spacers. I know Lense Corse do the LC818 but getting the right size is proving tricky (everyone wants to sell a staggered set).
Pics of the car yet?
Oh and today i took my car our to mallala for the g1 drift.
Drove half a lap to the start to get some different camera angles and went to start it and had no power left >_<
Getting your car jump started in front of a few thousand people on a race track is embarrassing... New battery this week methinks...
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah...but NA Mercedes V12.
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
