OK, so I just fitted the engine cover back onto the car to double check if it will fit with the 17mm plenum spacer. When I fitted the spacer and the cover I thought it was hitting the bonnet so took it back off. Ive been thinking about it during the week and for some reason really wanted the cover back on whistling.gif
I put a nice smear of Vicks vapour rub on the 6 bulges of the cover, then closed the bonnet and started engine and gave it a few good revs. When I lifted the bonnet I found NO Vicks on the bonnet lining. So I am now going to make up some play dough and put a 3-5mm layer on the engine cover and try that. I do this when building my Valiant engines to check piston to valve clearance with a BIG lift cam. This way I can cut it and get a cross section of the play dough to see exactly how much clearance there is.
And I also pulled out the rubber grommets in the cover and turned them upside down, this sat the cover about 2 mm lower.
Edited by slippylotion
I know the cover does look good and keeps the motor looking neater but I can tell you it makes the motor (intake) much hotter than with the cover removed. One of the biggest issues I ave seen with covers left on is the rubber parts becoming stiff and brittle sooner.
Busy day today, gave the car a service, and while I was at it, fitted up:
Fumoto Oil Drain Valve
R34 Intercooler
10psi Actuator
Yellow Jackets Coilpacks
Replaced the HKS pod that came with my car with a stock airbox and Apexi filter
And gave my AFM a quick clean with contact cleaner
R34 Intercooler
10psi Actuator
Good work -exhaust next on the list or is it already done?
Thanks, dump pipe's next on the list. Has factory Nismo option exhaust on it, and like how quiet it is, so wanting to keep that, at least until my daughter's quite a bit older. Just wanted to make it a bit more fun for occasionally giving it a little on the way to work and back :P
Itd be fine (and good price too!) if used in conjunction with a pigyback setup to finetune it for your setup, ie + SAFC + SITC, or + emanage ultimate
ie, like Im running chipped ecu tune + AEM Fic/8, which is emanage equivelant
But in saying that Ive got a z32 ecu here to nistune-chip, once Ive bought a harness patch extension to completely rewire everything. After cracking piston #5, shattering the rings, and cracking the rings on piston #4, Id prefer a full tune via Nistune.
You can do a Nistune tune on the Stagea ECU so you don't need the Z32 ECU.
Sadly you can't Nistune the S1 Stagea (or the R33 Skyline) ecu - only the S2 or R34 Skyline.
It looks awesome!
Replaced my battery Friday night. In the dark and rain, because the other one finally gave up completely.
Should be ordering shocks and disks this week, can't wait!
It looks awesome!
No BC's Ryan?
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
