  On 08/08/2011 at 5:17 AM, ironpaw said:
LOL took a month for him to start work on it?
I take it he's doing this for free :whistling:
Contemplating getting the Nismo front bar...hmmm
Me likey :)
Hmmm, they were refurbished and in primer WEEKS ago; but when he gets busy...
The Nismo bar is porn; if I could've found one, that's what I'd have.
your wifes gonna chop your balls off.
  On 08/08/2011 at 2:46 AM, impul535w said:
No BC's Ryan?
Yup, BCs. Looked at heaps of others but everyone is so happy with their BCs why bother? Seem like the most practical, and one of the cheapest, options.
Looks like I'm getting a set of DBA 4000 disks too, hopefully find out tomorrow :ph34r:
  On 08/08/2011 at 10:01 AM, scotty nm35 said:
Thats been dropped I would say, I cant see the throttle linkage doing that.
hey ill bring your filters around tomorrow, i havnt been feeling so wellsick.gif
Ok so I've done something. Took the airbox out last night and now my Atessa light is showing on the dashboard. I believe there is a relay right near the airbox, which makes too much sense to not be the problem, but everything looks plugged in and ok.
Is there a common problem with this thing?
And it's the relay UNDER the airbox for the 4WD, not the ones next to it, isn't it Brad :whistling:
Something for the "What haven't you done to your Stagea" pile, I haven't ordered my BCs because Just Jap haven't got any stock. 7 day wait at this stage, which almost makes it worth going to Street to Track.
Brain fail. I think it's the check engine light that is showing up. Two years of no cars and longer with no Nissans. :laugh:
Only other thing is plug in the boost controller/turbo timer harness in last night. Can of worms opened!
Edited by jasevr4
Did you unplug the OEM boost solenoid?
Id say check the error codes, theres a squence to get the CEL to flash which corrospondes to OBD2 error code list. The squence is documented here: http://www.m35stagea...ic.php?f=6&t=11 and the error codes: http://www.m35stagea...ic.php?f=6&t=12
Checked the codes. Realised how much I blink usually hah.
Pretty sure it was P0100 Mass or Volume Air Flow Circuit Malfunction or P0110 Intake Air Temperature Sensor.
Either way, cleared the codes and it's fine now. I'm wondering if I clicked my car onto ON without the AFM plugged in or something..
:rofl: I have the same issue.
That'd definitely cause the CEL light to stay on for a while, it would eventually turn itself off apparently, but when I've had it happen to me I've always just cleared it.
If that was the cause, it shouldnt come back on now. Easy fix :thumbsup:
yeah turning the car on without starting it WILL throw a CEL if the AFM isnt plugged in.
and dunc is right, it will clear itself after a few days, but you can clear it if you want yourself......
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
