Driving to work this morning, the heater isn't working. Just blowing cold air all morning. Temps were normal, didn't think too much about it. Just turned the climate control on and off a few times, didn't seem to do anything.
Then closer to work, temp is creeping up. Higher than normal but nothing ridiculous. Of course before long it's just below the H, I pull over and it's steaming.
Thing is, I reckon it's been cracked for a while. When I picked it up from the Toll depot there was a bit of coolant around the place, but the car never seemed to be complaining so I figured it was a previous coolant splash that had never been washed off. If this wasn't the case, then I've most likely been driving it around like normal, leaking the coolant slowly (the TransportSA inspection guys didn't say anything either), to the point where it's empty.
So yeah that's how my hour and a half commute to work was today. How hard is it to find radiators for these things?
Sorry to hear that. Seems like the previous owner hid the issue pretty well...or did the issue not manifest it self till now?
That was a m35 one yeah? Anyone know if v35 and m35 are identical?
Brad, ducati02 on here, did his radiator late last year - brief summary of it http://www.m35stagea.info/forum/viewtopic.php?f=2&t=114&p=1048
Are you sure the radiator is cracked? The water only has to be half a litre short to show these kind of overheating issues, even 200ml will cause problems.
Can't say I'm 100% sure. Any way to test without one of those pressure things?
Just so you know the V35 manual one fit's in with a little bit of cutting......I had one in mine....I lent it to someone about 6 months ago for a couple of weeks. :P
When I do get it back it will be for sale.
Usually the Oring goes on the top tank. It may hold pressure fine until its hot. These can be replaced.
I would just fill the system from the rear bleeder, behind the drivers side head, and check it a few times to make sure its full. If it still leaks there is a problem.
The coolant can spurt out the top of the overflow container if it gets full which could be your spray in the engine bay.
They also had to fit a radiator to mine prior to compliance as it had a split tank, so it must be common?
You reckon fill it up and give it a few more days to see how it goes?
Where is this Oring? I need to get FAST sorted out so I can look at the diagrams...
Yep, I have had the overheating thing so many times, I just fill at the rear bleed and it goes away. That said, if it is leaking you should keep a few litres of water in the back just in case.
If the top tank is cracked you will definitely know about it. The Oring seals the whole underside of the top tank and usually only weeps when warm, sometimes it sprays out from one side.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
