What Have You Done To Your Stagea Lately?
Hanso
they regesigned a few parts mid-way through the run it looks like
when stripping stephens wreck, he had some small bits that were better i guess. so they are now located on my car :)
maybe it fell off. more than likely did.
OR its a different design as mine is a 2001 model. stephens 2002 had a different undertray with metal supports in it.
Yeah, IIRC he bought a new "rear" undertray from Hornsby Nissan which had more metal on it.... or something
I took on a little project with the Stagea.
For those who like the idea of fitting GTR sway bars to their C34 but can't be arsed forcing the rear bar to fit, check out this thread below:
http://www.skylinesaustralia.com/forums/topic/375348-upgrading-sway-bars-to-stagea/
I fabricated up some mounts so the rear GTR sway bar is a comfortable fit.
:thumbsup:
Put R32 GTR Sumitomo brakes on tonight. PMu pads.
Two issues - one, didn't cut/bend enough of the LHS stone guard out of the way - so it scrapes on left hand turns - easy fix.
two, I seem to be getting a small leak from the banjo in the back of the calliper. When I pulled up after bedding them in, there were patches of BF around the wheels, both sides. Not good. Braking performance was good, so not a massive leak. I think the OEM's are slightly different in operation. They have a little seat where the copper washer sits into the calliper. The R32's dont have this. So what I think I have to do is smooth off the surface where the banjo goes in to make it sit flush and seal nicely.
Either that, or shorten the part that goes into the calliper- thats been mentioned by other people. I thought I wouldn't have to do that because I removed the original restrictor out of the sumitomo callipers.
Anyone else have similar experiences?
Alex, did you use new copper washers on the banjos? I've fitted several sets of Sumitomos using banjos, rather than flares (as per std) no leaks, no issues. With the taper seat gone; the banjo shouldn't bottom out. Wash the residual fluid off with some soapy water and see if it reappears.
i wouldn't smooth the surface at all
it will be nice and flat at the moment but as soon as you hit it with a file or something its going to become uneven
i'd leave it to a last resort if you can
Yep, it should be fine with some new copper washers. If not, the area will need to be spotfaced to give a nice flat mounting surface.
Edited by Daleo
Fixed it.
Could not find copper washers, only seemed to sell them in imperial not M10! Nissan parts wasn't open sundays. I removed the lip off the old washers, and gave the bolt a bit of a grind down, sanded the surface smooth as, whacked it back together and fixed.
Pipster- my callipers had some kind of finish on them , a little rough in the alloy. Bit of sanding gave a good finish.
Craig came round, fixed my grinding problem... was that little bit of alloy that I should have got rid of in the first place, but it only fouled on one side, and only when turning!
So brakes are on and working a treat, so much better and heaps more confidence in them than the OEMs.
Craig also broke out the magic tool, and we lowered the back of the car - by popular request! Photos later, when I can be f'd.
So all in all, a very productive weekend - thanks again to Craig for helping me out. What a champ.worship.gif
Fixed it.
Not a problem with the help....I've run out of things to do on my car and yours is the closest to me! :P
On other news I got my head pretty much around your HKS Kit....hopefully I will get a good nights sleep tonight now.
