I spent the whole day making my tracking unit close all the windows and sun roofs lock unlock doors remote shut down all via sms. Doing both sunroofs were a little pain in the ass to hook up but finally got it
It all works great now
Oh yeah made my auto lights turn off with the ignition only not the door because of the turbo timer
I am happy now
I am happy now
Excellent....can you drop by my car and do the same mods for me :D
Both those things shit me too. Especially the turbo timer which I will probably disconnect.
YES!
DO SHARE!
right now i got the lights turning off when the turbo timer turns off it works great but i want it to turn the lights off when i hit the alarm thats saturdays project
Koyo in, B&M Supercooler in, front BC BR's in.
Just need to bleed the cooling system now, get the rear coilovers in and give her a massive clean up.
Pics! :cheers:
With much trepidation I chopped several holes in my rear Aero bar to re- fit my towbar tongue...
Success! Had to cut a little larger than I wanted to to allow clearance for the bends in the bar but no scratches in the paint, so I'm a happy camper. Took a while, as I was trimming away small sections to sneak up on the final fit.
post-61153-0-35079200-1315189681_thumb.jpg post-61153-0-62118600-1315189772_thumb.jpg post-61153-0-66921000-1315189838_thumb.jpg
Edited by Daleo
You too Daleo, description is useless without pics... :whistling:
Fixed! :nyaanyaa:
The space at the top looks farking huge in the pics; but it reallly isn't that noticeable, and from a standing position; it's virtually impossible to see.
I wish they'd just made to tongue with one bend, instead of two; I just couldn't fit it through without a slot that big.:sleep:
post-18615-0-66490400-1315194341_thumb.jpgpost-18615-0-53311300-1315194392_thumb.jpgpost-18615-0-95696200-1315194437_thumb.jpg
Useless photos. We just moved house and I can't find our camera.
That and the grille is on it now and I couldn't be bothered taking it off. I'll take a better photo of the trans cooler when I change my grille. :whistling:
Things to note: The G35 Koyo Alloy radiator is about 20mm longer than the standard M35 unit, and the top and bottom tanks are approx 10mm wider. The airbox sits hard up against the fan shroud bolt, and the over the radiator cold air intake is not in a slightly different position. I'll likely shave some plastic from the airbox before long to try and get everything to fit nicely, but just an FYI - this isn't a perfect bolt in solution.
Given the additional length, the ends of the fan shroud need to be removed.
That said, the radiator itself does bolt on to everything perfectly. No custom mounts, AC condenser fits perfect and the standard rubber mounts go on it easy.
Can't figure out of it's waaay low on ATF fluid or ridiculously high on it. What came out of the hose last night seemed a lot darker than what I'm seeing on the dipstick. Since I filled the car via the dipstick "pipe" I'm guessing I just need to let it settle for a while before checking the levels. I imagine I'll have to add a fair bit of fluid given that it's probably dumped ~400ml in the swap, and I've added some extra hose and a whole trans cooler to the system.
yup same with putting a V35 standard radiator in an M35, well, the 3.5L one.
good work! looks nice in there.
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
