Well I got my braided lines and wireless reverse camera in the mail yesterday
When you figure out how to make it work let me know. Mine is useless. Pioneer screen goes black when it kicks into reverse but no images. :rolleyes:
Ask Brad (ducati02). He will be making mine work, he will be able to sort it for you.
Well I got my braided lines and wireless reverse camera in the mail yesterday, just waiting on the rear rotors and suspension now.
Not sure if I'm even getting my suspension now. If I don't hear from Street to Track by tomorrow I'll be reporting to the bank to get my money back. Service is terrible, and still waiting for my shocks 3 weeks later. Now they guy won't even respond to emails. Major disappointment.
Sorry to hear dude. Didn't someone else use them and found get were ok?
I had some major issues with emailing him, was taking hours for the email to get through to him and reply back to return. I thought his provider or mine were very laggy. Hopefully this is the case... Do you have his number?
Either your camera doset have supply when in reverse or your video isnt pluged in. A black screen means there is no video input. Try another video source into that channel.
Re Street-to-Track, I used him for my BC's and found him good to deal with. He replied to my emails by next day at the latest. They did take a while to arrive, but I thought that was 'cause they were custom spring rates. IMO the hold up will be at the factory, but that doesn't excuse him keeping you in the dark. I hope they arrive soon Ryan.
Edited by Commsman
I went through him and to be honest it was a pretty smooth transaction and they arrived way faster than I thought they would. Hopefully it works out for you mate.
So what is the game plan for rear spring removal? Do you need spring compressors?
Thats why I gave him a go, plenty of positive reports on here. But since I handed over the money his attitude changed and giving me the time of day has been a hassle.
I think his number is on the invoice, so I'll give him a call tomorrow.
Na just unbolt the lower control arm from the hub, I have the car just off the ground and a jack to take the load, pull the bolt out and release the jack slowly. Job done. Will take all of about 10 min to remove both sides :)
Mike.
Thanks Brad.. I've pulled out the head unit and made sure everything is connected so my next guess is power.
Mike.
Cheers Mike!
Me and working on cars in a rush does not mix. Just stuffed a high tensile bolt using a little bit too much force. Need more patience! :rolleyes:
Anyone know if 55110FB and 55269+D in this picture is the same as any other Nissan? I've seen this type of bolt before, maybe just on my C34 Stagea. Any suggestions as to where to get one? Try and get one from Nissan or just go to a fasteners place?
:thanks:
Pretty retard move on my behalf. The bolt was a tough one to come off, had a little slit through some of the threads. When I threaded it back on by hand it went a good ten or so turns and then stopped. I figured the thread would come good given just a bit of force and before I knew it I had a very useless piece of metal.
Followed your measurements Dale and they are WAY off hahah. I'm sure I screwed up something. The front end is slammed while the rear end is slightly lower than stock. Might raise the front this weekend otherwise I'll just wait until my wheels rock up.
Edited by jasevr4
Pics!
Apparently mine actually might be coming, STT just don't have any updates, and I get the impression he couldn't care less.
Since he's now over both deadlines he gave me and hasn't even seen a shipping confirmation I have no idea what is going on. But I won't be doing this again.
:thanks:
Would you believe Jetwreck and I (but mostly me) stripped exactly the same bolt in the rear of my car when lowering the rear!!!
Had to go for a quick drive to somewhere we knew there were some similar boltswhistling.gif
Warning to others- they strip easy!
I have to say I feel like a lot less of a retard now.. :rofl2:
FYI the bolt and nut would have cost me $18 genuine from Nissan. The bolt would have come from QLD and was one day away while the nut would be a 10 day wait from Japan.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
