took car to nissan service to sort out the ECL issue
if u guys remember, the codes that came out were 1110, 1111 and 1135
turned out there was an opened circuit at the intake camshaft on the passenger side, so after an hour's work to fix the wiring and $121 paid to nissan service, no more ECL coming up...happycheers.gif
the guy at nissan service asked me how i found out the codes without OBD2 scanner, i told him i talked to the ECU and it answered me lolwhistling.gif
lol just a short drive to the city this morning and i used a lot of fuel
nah its the same as a t30 xtrail - 22680-6N21A
thats for the hotwire only, not the whole tube - which isnt required anyway
Found a couple of links;
http://www.nissanpar...2680-6n211.html
http://www.cyberspac...n-uk/p1178.html
Slightly Cheaper price.
Edited by Daleo
Link doesn't seem to work?
Dunno what happened to that one, Google the updated part number (can't remember it, posting from phone) and it'll come up. Price was $190 aus.
Try this one :)
http://www.cyberspaceautoparts.com.au/contents/en-uk/p1178.html
Which Nissan dealer Syd?
it's the camberwell one cam, they were quite nice although they admitted my M35 was the 1st one they ever seen and with some luck they saw another one drove past on the same day lol
Cool, sounds like a reasonable dealership (Yes, the shock is overwhelming!!)
Went to Jb Hifi yesterday before work and was looking at getting a new cd player for my car but wanted to keep the HDTV i got in my car atm. So the guy there said i can keep my oem cd player in my rx and just get a FM extender to get all the fm stations in australia. Well this cost me $25 from autobarn so i was strapped. That was until i took my dash apart and seen that our aerial plugs are twin pin units and the fm extender is a single. So today i ordered the adapter from the UK for it. Cost me $75.00 AUD so all in all im still happy i get to keep the OEM unit. Just got to wait a little longer until the adapter arrives.
http://www.nexxia.co...ategory=Antenna Adaptors&section=Car Audio
I got my aerial adapter at auto barn for $10
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Edited by Ross
Fitted the new suction pipe toady with the help (should read totally lost without) Craig (aka Jetwreck, is there any thin on cars this man can not do).
This was certainly at the limit of my ability and patience to work on cars.
Thanks to Scott for hit great fabrication, only a slight mod of cutting a grove into the bottom bracket of the suction pipe so it could be placed over the shaft of the bolt.
For anyone looking to do this mod make sure you work with someone who is a contortionist as there is no bloody room to work in.
Net result is a good fit with a little bit of tidying up to be done on pipe work but the car feels even better down low in the rev range. Not had a chance to really test the top end as I am conscious that I need to finalise things under the bonnet and aware that I am currently running 17psi and want to be careful of hitting fuel cut.
thanks all.
Cheers
Andy
Had my mate in give the wagon a good cut and polish and wax job while I'm in renmark for the weekend. Looks very
Nice now. Just need to wash it again when I get
Home and give it another wax to finish it off.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
