swapped the transmission over yesterday with the 'good one'
big thanks to craig (jetwreck) and andy (andy65b) for their assistance.
the box is pretty much the same, just lacks that overdrive lockup problem which was a massive pain in the ass.
cant wait for the shift kit to go in!!
I hate the way the convertor clutch locks up so early. Previous jap nissans I've had they don't lock until your over about 85km but the m35 seems to lock at about 60km or lower.
Edited by slippylotion
+1.
Around town or anywhere up to about 90km/h, I flick the stick across into 4th; locks out top gear and is generally a bit more responsive.
Doesn't kick down as easily, but I don't find it too much of an issue; much better than constantly shifting up and down all the time, because you can't maintain 70km/h...
I disconnected the torque lockup two years ago, The high stall converter keeps revs up over 2500 when cruising and shoots up to 4k fairly quickly once boost kicks in. I pay the price with less fuel economy though, I still need to fit a switch near the gearstick to lock the converter on long drives.
Speaking of overdrive, is it just me or do these things want to be in 5th gear asap. Cruising at 60kmh in overdrive at 1000rpm seems kinda stupid..
once the box went into lockup, if it was in it long enough it wouldnt come back out of it
and yes they get into 5th quickly, but i find now if i move my foot a little it will kick back no problem.
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Hey Ross, what exhaust did you put on? And I like your wheels - car looks great mate.
Picked up my autech on Sunday morning and fitted some 20" rims I had laying around straight away lol. Hopefully getting front pipe, highflow cat and and 3" cat back fitted this week
we want pic's!!! :P
Thats a good time.
1st owner of my stag (CoolPC) ran a best time of 16secs, with catback exhaust k&n pod filter & 10psi
Would love a strip in Sth.Aust to see where it'd be nowadays.
Once the engine is refitted, of course.
$4k is the rebuild price, including engine out/in, tune after run-in, CP piston kit, complete block work (bore/hone, acid bathed, etc), head refresh & new MLS gaskets.
Spent about 3 hours scrubbing away at the double sided tape/foam that the japs must have used for aerials. Unfortunately the previous owners never bothered to remove them so they were pretty much rock hard.
Also debadged the rear end.
Going to get some quotes on how much to spray my wing black/spray my new grille and fix a small dent in the passenger door and most likely respray the bonnet tomorrow. Previous owner did some "touch ups" that most people would refer to as graffiti. I'm hoping I can get away with all of that work for under a grand. No idea though..
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
