Had a 70% (?) tune done on Saturday.
No a full tune as we had fuel failure, either filter or pump :(
On the plus side, no more "boost/fuel/air flow/whatever you wanna call it" cut and a different throttle feel.
Throttle is a bit soggier at the moment, but at least I know it can definitely be modified :whistling:
Looking forward to hearing the end result! Hope all goes well.
Deatschwerks 600cc, about $100 each when shipping is added on.
Wow, not cheap. I could have gotten you ID 1000's for that mate. Do these have the stock denso plug though? Im guessing thats why you bought them?
Gave the car an oil and filter change..
Whilst there also installed with the help of Craig (or should I say I helped him) a replacement actuator with spring tension..
This is a great mod... :)
Had to turn the boost down as was holding 20psi to red line.
The improvement is very noticeable with the motor being less peaky and drives much more linear from a stop to the top end of the rev range. :banana:
Grab a Nissan genuine filter and I use a 10w-40 or 5w-40 oil, the brand is up to your liking as this question starts world war 3 on forums, along with asking the frequency of changes.
Too true. The above is the general concensus, you want a minimum Group IV oil. I go for Motul 300v and Im fine with Ryco filters (445 I think is the specific model/size)
I've always found Ryco filters overpriced for average quality. I've got a Nismo filter on at the moment, which seems fine, and about to change it for a HKS one when I do my oil change. Going to try the 300v eventually, not sure whether to do it this change for the track day or use the leftover Valvoline first.
So I finished fitting the intercooler today. Not a great idea to do while you've got a cold/flu thing, but I needed to get it done and the car mobile again.
While I was at it I threw all the black clips on the front bar in the bin, and replaced them with brand new ones I bought on ebay. I also soldered the pins on the factory boost sensor at the same time, so the boost gauge works again (finally!).
Only thing is I've now got a bit of white smoke. Not sure if it's burning off the excess WD40 I used on the silicon joiners or what, but hopefully it goes away after a bit of a drive.
Paint not to your standards? :nyaanyaa:
Haha smart arse.
If you're going down the Ryco route though, there are other people who produce filters cheaper which are just as good if not better.
And if we're going to have a discussion on paint I'm not sure I'm a fan of the bright pink HKS filter :P
BTW - NEO is $112 delivered to you door for 5LT's!!!!.....the only other oil I would use would be Royal Purple....Motul while good fall's short of both the NEO and Royal Purple IMO!
LET THE OIL WAR"S BEGIN!!!!!!! BAHHHHAAAAAAHHHHHAAAAAAA
Edited by Jetwreck
He runs the NEO oil.
I'm trying to work out what physical difference there is, and I can see the Motul 300v is more viscous than the Royal Purple, but haven't worked out any other significant differences.
I can't find the NEO datasheet - their own web site doesn't even list a 10w40 anymore...
I sent a snapshot of the tin to Cam recently...I'll post it up next time I remember...I also run a Nismo Oil filter......$10-$15 extra doesn't bother me either.
Are these M35/V35 specific? Is there a long wait time on them? I was really hoping to change the oil this weekend..
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
