I think the reference was to some probs you had that could be attributed to less than ideal maintenance before you owned it.
Correct me if I'm wrong, but things like banjo bolt blocked (first turbo failure?) and the sludge you found when you pulled your oil filter/associated mounting hardware off. Chances are a few oil changes might have been missed pinch.gif .
it was probably me more than anything. when i bought it i never serviced it properly. used el cheapo oils and stuff.. when I came on here I started looking after it..
What about your tranny? Or was that your own doing? RVO said it was pretty trashed...LOL :whistling:
nope? he said that for the amount of K's that the car had done it seem like it was pretty spot on.. he said your pan must have been dropped and changed..and thats why it looked like it was in good nick.. with the previous owner your car had, i wouldnt talk buddy :ph34r: i know a lot more about your car than you think..
just sayin lol
bahhhhaaahhhaaa!!
Jaffa sledge time!!!
lol craig arent Jaffas red? should start calling you a mars bar..
What the hell is he doing trashing his tranny? Is that what the young kids are calling it now?whistling.gif
lol yeh join in the fun dale..
Sorry dude; I just couldn't resist.
200 is good? I take it you got your electrical issues sorted & retune done?
200 is running ok now.
all the electrical stuff is sorted $300 later.
got scott to weld me up a suction pipe for the stock s15 airbox and z32 AFM. perfect
put a new front mount return flow cooler in, which is proving to be better than the massive Greddy one.
standard s15 BOV with grub screw so no more fully sick dosing..thank f**k.
all I wanna get now is a new fuel reg, as the one i have now is malpassi rising rate(a piece of shit)
then i'll head up to cihan for a tune..if i hit over 200kw ill be happy. this has tooooo much response as it is.. ass goes out 2nd and 3rd in the dry.. quite fun.
Back on topic, I cut the centre bar out of the opening of my Aero front bar; I think it looks better (too late anyway) but it was a breeze with my new cheapy Ozito multi-function tool.
The ones that have an oscillating (as opposed to rotating) blade; put the blade against your hand; big vibes, no cut. On a plastic bumper, it just pushes through literally like a hot knife through butter. Very neat, no burning or melting of the plastic, but no monster furry edges like a hacksaw or jigsaw cut.
Still dragging my feet about the mesh; everyone else seems to like it but me!whistling.gif
Got new tires and drove it to 200,000kms, like a boss.
Sorry for the off topic but? 576.6km and still 1/4 tank of fuel :O. Is the m35 really that much better on fuel?
i like the bigger mesh leb mesh looks too cheap
from memory I think his car is a VQ25DD.....regardless on the Fwy I get in between 650km and 700km to a tank providing I don't hit it.....with the VQ25DET......around town they tend to be a little shit before getting a tune!
Yep, I think the hexagonal mesh I've got will be better with a big cooler behind it; but for the next few weeks, I'll be sticking with the Uleh bro.whistling.gif
hexagontal mesh is the standard stuff yeh?
Aero looks good black and without the foggies IMO! Not much of a fan of it normally.
Mesh needs more black I reckon.
A close up of how the stuff I got from Autobarn (I think it's Monza??) looks behind my front bar.
mesh does look good......pity about the gay pascal metallic blue colour around it!
Yes, I think the OEM is diamond mesh though. Mine didn't come with it, and given the pissing about I had to go through just to get the blanking plates; didn't even bother.down.gif
Cam, lol, it is black, just the way the light is hitting it. whistling.gif I'm actually quite happy with the look of the Blanking Plates versus the Spotties myself.thumbsup.gif
Looks to be exactly the same thing; mine was SAAS, but same difference. The stuff I have to replace it is slightly smaller openings than the OEM and hexagonal in form.
And I'll have enough left over for another car. I'm also convinced the Aero cools better than the smiley face front; Win!
Edited by Daleo
LOL, you just can't help it can ya!
Fair enough. The way that light is hitting it, the mesh almost looks like the silver version.
Aero definitely lets more air through than the standard RS bumper, no doubt about it.
Interested to see your replacement mesh :)
Well go on!! The suspense is killing me...go ahead and tell me what dimi did to it...
hook, line...
annndd..
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
