looks good Dale, probly be even better if you took those blanking plates out
Nah, it looks pants with them out!:blink: I didn't have them for a week or so, even with mesh covering the spaces; it just didn't look right.
You know what would look great in there... Some spotties. :nyaanyaa:
Yeah yeah, but I think spotties would be a better choice personally... :rolleyes:
I've got the switch & relay parts C/O ironpaw & Prince Skyline, and I'll get my guru mate to sort out the wiring (cos I'm lazy & he owes me a favour) so it'll happen in time.:thumbsup:
Dale will get some spotties when the Damn bar gets on a f*king boat....arrgh
No stress from my end; it takes however long it takes.:cheers:
Hey Dale, I like the look with the support cut out of the front, and checked mine & it looks like the mesh goes right across in one piece (never noticed when I had it out recently).
Can you send me a close up pic of how the bottom cut turned out? I'm concerned that will leave a rough/dodgy edge visible, if I don't have a specialty cutting tool like you used.
I'll take one later today & post it up. When I did the towbar cutout, I rough cut with a hacksaw blade then used a Stanley or scalpel blade to shave the cut smooth, works well; it's very soft plastic. As long as you touch up the paint on the cut edge; it'll be virtually invisible.
Seriously, unless you crawl around on the floor; you can't even see it.thumbsup.gif
Thanks Dale. You did a good job; very neat. Did you colour the edge at all (permanent marker, black paint) or is that the raw colour?
Since mine is silver I may have to find a creative way to camo the edge - if it is visible at all.
It looks like Dale has recessed it a bit, so there wouldn't be anything exposed I wouldn't think.
Might have to do this myself, good work Dale! :thumbsup:
What have I done to my Stagea? Pulled out of the SAUSA track day because I have to go to Sydney for work >_<
But I did order my F con V Pro setup... so all is not lost! :cheers:
So while I pulled out of the track day, next time I go I'll have the shift kit, trans cooler, fuel system and computer in, and will be running E85 :banana:
Really can't be bothered fitting the rear shocks and brakes today though. Two weeks of cold and flu backed up by a sinus infection will do that... :down:
Cheers Guys, I'm getting used to carving up expensive bumper bars now...whistling.gif
There's a ridge about half a mm high from the level of the grille aperture, as I didn't want to carve into the paint, and I've just temporarily used a black marker to cover the line of grey primer that the cut exposed.
The plastic is black, but a paint touch up pen will hide the evidence perfectly. The indent against the mesh is just the way the plastic is moulded, but it's only about 1mm.
Same... Thanks to Cam for all his help so far. Should be a bloody good thing when it's all up and running! Can't wait!
Gave the m35 the 8ltrs of E10 100oct from emptying the tank in the 180SX before it was filled with E85. Just a pity it's raining so I can't really test drive it.
Edited by slippylotion
Changed the oil - was hoping not to have to do it before the turbo kit, but when it was dropped at the workshop I got all embarrassed and felt sorry for herwub.gif
It was so black- now its fresh.
Also did the ancillary belts. Pretty painless really. They were starting to squeak and piss me off.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
