Got the new 3.538 diffs in.....got some good umph now!!!!
My fears of the speedo being out are cured.....speedo and gps are exactly the same differences as they were before.
Care to explain how a change in diff ratio makes no diff (oh look, a pun) to the speedo reading? Am I missing something obvious?
Installed my new ECU this weekend.. NISMO Sportstune :banana:
Very first drive it is obvious the difference with the car being a lot more toey of the line. Best part to be experienced is in the mid range now coming on much stronger and faster.
Next step to put it on the Dyno and see what the AFR's are like and what the actual power out put is.
Is this enough power.. :whistling:
because (as i mentioned ages ago) the speed is taken from the ABS sensors on the OUTPUT of the rear diff. therefore no matter what ratio the diff is, assuming you dont change your rolling diameter, the speed will always be correct as the speed is measured after all the gearing.
where'd ya get that ratio, 34 gtr? I was thinking the same thing today.....
btw hills have a 4wd dyno. what computer?
Ratios are from then nm35 vq25dd or the pnm35....
....Hmmmm waiting for mark to give me a buzz back on the dyno.....to much longer and I'll be going to Victoria for a touch up!
Edited by Jetwreck
The Nismo ECU's.. how do they go with economy? Better/worse?
Emanage is a piggy back...so it needs an existing ECU to control.
The nismo ECU has certain "awesomeness" in it that makes the car a bit better to drive....and speed cut too I think
Craig's car has the Nismo + emange combo...
better.......you have an economy setting, it uses the snow button!
Worse......the drive is a lot more inviting so you tend to get up it a little more.
I think the main thing is no speed cut and no throttle restriction isn't it?
Has anyone with the Nismo snipped the brake wire?
Don't need to worry about that now though... :whistling:
I think he means with the fcon, the stock ecu still controls the throttle though. There are 4 wires extra in the loom plug I can't account for which may make some changes, not sure.
Doesn't explain how the throttle changed on my car.
Both much more responsive and also more soggy depending on map selected...
Without the infometer you are only guessing though. It could easily be tune related.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
