haven't changed anything....And I don't get a constant figure either...jumps from as low as 11.x to 13.x as a rev higher
Below 2.5k rpm its like 15-6ish :ph34r:
WTF is happening...
You got a leak somewhere?
Just installed the USA-spec pa15-nis. Very easy plug and play set up, only 3 plugs.
The sound is awesome as I expected. I can't recommend this enough to anyone (like me) that's wants to keep the factory single din stereo to keep it intergrated with the factory tv screen and wants to add in an iPod/iPhone to it. You can also add another audio device into the unit.
Music is all control either via the factory head unit or the iPod/iPhone itself and it charges them.
Only $160ish delivered via eBay out of the US.
Edited by slippylotion
Just took the car in for a wheel alignment, front bushes and ball joints are knackered.
I know SuperPro do the bushes, but anyone know where I can get the replacement ball joints?
I've been looking at foam lances for a while now for my Karcher; prices ranged from $200 odd blink.gif to just under $75 delivered (UK). These are pro quality items, and you can adjust how much foam you actually get.
Anyway, I saw this at Bunnings; http://www.karcher.com.au/aus/Products/Home__Garden/Accessories.htm?&sdp=ac&pid=26418480&accessoriesGroupName=Special+applications&pn=Foam+nozzle%2C+0.3+litre&title=Foam+nozzle%2C+0.3+litre&refP=%2Faus%2FProducts%2FHome__Garden%2FAccessories.htm%3F%26accGrNm%3D10011604__Special%2520applications
2641848_popup.jpg It has a 300mL cup and was only $15!
It works great! Took a little fine tuning to get the mix right; and you need to work fast in the foaming stage, (the cup empties fairly quickly) but now I'm foaming like a rabid monkey!banana.gif
For anyone who's wondering; the foam softens the muck on the paint better than just hosing; allowing you to pressure wash off most of the stuff that scratches the paint when you manually wash.
The more you can get off without touching the paint; the less fine scratches you put on the car. On a black car it makes a big difference to how often you need to do paint correction.
New front upper control arms with nolathane rubbers (or SuperPro????) for my NM35 today at Wholesale Suspension, Penrith, NSW.
This was on top of replacing the lower ones abt 6 weeks ago (by Jetwreck). The knock in the suspension had gone away but came back
again after a while, particularly when under heavy braking.
Picked the car up from Pedders, rear is dumped, but only just level with the front. Weird... but can't go any lower on the rear. Haven't measured yet though.
Got my new blow off valve in the mail today, Turbosmart Nissan specific dual port. Nicely made unit. Fit it this afternoon, not too hard, just had a higher pick up for the hose. Set it up as plumb back, and set it as stiff as it went.
Gives a fair bit of flutter, but other than that is all good. Will back off the stiffness in the morning and see if that lessens the flutter. Main thing is it fixes the 'farting', guess I'll find out over the weekend, with a drive to McLaren Vale and back.
Picked up my car from All Type today. Largely happy with the job, would have liked them to touch up the car more, but I think I always knew that the job wouldn't be up to my standards..
Grille is painted and fitted. Wing will go on tomorrow when I get some adhesive rubber stuff for it.
anyone seens pics of a stag with big wheel flares?
Like this?:whistling:
http://www.eurotuner...dl/photo_1.html
Ghetto; but pretty cool...
Edited by Daleo
yep, that is indeed a good start. too small but at least it gives an idea of how they would look.
actually that looks like a well built car at a glance
Lol, I was only really referring to the exterior; rivetted on flares over the existing rear doors, etc.
Everything under the skin is beautifully fabricated.:thumbsup: Definitely has attitude.
ahh yeah, some practicality lost, but otherwise it's pretty good. I like a home built race car, they can have heaps of good ideas. Like the rear door on that one for instance
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
