That's great news Craig. I hope you work out the CAS issue soon & get back up to full power. No problems maxing out the standard injectors? I reckon they are highly under rated, especially if you've increased the flow via better pump or FPR.
even better new Leon......Problem is solved.....I now have CAS!
Car goes like stink again!......it's very neutral in balance........power is just right!
I bet thats a relief! Great work.
Are we allowed to ask what the problem was? :)
Mate, that is great news. Btw, that stink would be left from your last passenger. I recommend a steam clean.
It was fixed by cutting the top off a zip tie and using it as a shim on the CAS.........so in other words I had to change the angle of the CAS slightly. f**k I wish I had the money back that I had thrown at this problem. I think every expert that I know or Dad knows has either had a look at the car or tried to diagnose it. Alex and I found the problem because I decided to test my spare CAS's before biting the bullet and buying another brand new one and when changing them back and forth this time I found inconsistencies in the RPM missfire and startup....so I fiddled and applied pressure in different directions and it either killed it , cleared it or f#$ked up the idle.....at first I thought the plug was stuffed but it seems that when we had done the GB change the CAS location has changed ever so slightly.....I dont' know how either it does not make sense!
Funniest thing is one or 2 of the workshops decided to call me and Forums a waist of time and we don't know anything.
I have a small quote for them!
"IN YOU FACE MR MECHANIC!"
Craig Markland
I might just point this out to them those workshops as well!
Happy days to......onto the next part of the project!....ECU's again!
Craig Markland
So time to do a drag strip meet to put a time on all our mods... :)
I think SO!....I still need to get the new Box in, Change spark plugs and do an oil change first.
Plus fit new bitsph34r.gif.....wont be cracking a mid 12 second past as I don't have the E-Manage on anymore but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!
Edited by Jetwreck
.... but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!....running stock injectors.....on pump fuel
edited your post for more drama, lol
I drove another M35 last night that does 14.4's..........I know my car is a lot quicker than that so it should be very interesting....at 18-19PSI my AFR's are at 10.8 so it's still got more in it except the AFM is stopping it....needs to be clamped somehow!
Good to hear you got it sorted, bastard it was one of those seemingly intangible fixes (cable tie? Really??)
ECU's? I can help you out with that :)
Edited by iamhe77
Jaycar have fuel cut defeater kit that I used on my last 33. It was only $20 or so to build. It has a trim pot so you can turn the cut of voltage right down.
How do you add fuel to the map with the voltage clamped so low? It's not a set figure, it changes with revs/load compared to what the ecu is expecting.
I agree. If it does clamp the AFM signal to 3.9V, the ECU won't add enough fuel under highish load IMO. My car reaches 3.9V long before WOT. Nothing wrong with modifying the AFM voltage, but to run nice it needs to vary under all the conditions the ECU is looking at.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
