Dropped the rear a tad more. Happy to find I could move the circlip on the Bilsteins without removing the shocks but simply jacking up the collar. Also pushed the guards out a bit more. I used to think the "baseball bat is your friend" was a joke but I found I could do more with a bit of steel pipe in 15 minutes than an hour of stuffing round with a guard roller!
Finally got the buttons installed on the steering wheel, look great!
Also go the cruise control wired up, but still need to set it up.
Thanks to Leon for all the help so far - hopefully I don't have to call you again mate!
Fitting a runner spacer on Sunday, very happy with the results. Only drama I had during the install what snapping the head of a bolt but no drama as it was just the bolt that holds the trans filler tube to the plenum. :)
brought some basic stuff. got new spark plugs (ill re-gap), nd fuel filter. will install both along with spitfire coil packs on the weekend. which i have had sitting here for a little while.
and also for those that need diagnostic checks i have put a deposit on a diagnostic scan tool today. which covers most imports. M35 Stageas. skylines, Silvias (only ones i checked). doesn't have the C34 but might be able to look up under skylines.
Which scan tool did you order Michael?
Got my cruise control programmed tonight, very easy really. Leon's instructions are amazing, used Dale's ground wire idea and the Marvey Tech speed wire. Pretty happy with myself!
If I set it the car accelerates quite hard when you hit set, from 80 to 90, as an example. Just have to adjust the gain apparently. Will do this tomorrow then wire up the steering wheel buttons.
I do have an airbag fault light now. Looks like I forgot to push the black clip back in the first time, but it was still in when I pulled it apart again. Fingers crossed it will clear itself now that I've pushed it in, like a CEL.
Thanks to Leon for all his help!
new spark plugs, spitfire coilpacks, nd fuel filter installed. left coil cover off to keep coil packs cool. nd also found on of the connectors for coil pack is broken. so need to try nd find a new loom. nd did final fitting nd cutting of eye lids today. peter just needs to sand back nd create mould. nd should be ready to sell
Fitted our new Turbosmart Dual Port BOV (TS-0205-1026) today and took her for a test flight.
Solved the farting BOV issue which was getting progressively worse which was the reason for grabbing it.
Also appears to have reduced a bit of lag and made the M35 more responsive and feels like it has a bit more fire in the belly according to the Bum Dyno!
Even better was the fact it worked (for my needs) straight out of the box.
Running it in full plumb back mode too.
when it vents anything below 5psi do you get a flutter that pulses through out the whole driveline???
cos thats what mine does and i hate it!!!
What's wrong with factory Bov? I see a lot of you guys change to a/market.
Just block up the recirc whole in the factory unit and they hold a lot more boost. I did this to the factory unit on my 180sx and has held 20psi with no problems. I know of guys running more psi with the stocker.
Edited by slippylotion
If the original was working properly (as in not farting and causing the whole car to vibrate, like mine, even under moderate boost), there's no reason to replace it and i would have kept the stock one.
I could have purchased a second hand one and potentially ended up with the same problem or probably spent more (i din't even bother to check TBH) on a new one from Ni$$an.
I purchased the Turbosmart from Mick at BoostnImports for $387 delivered, great guy to deal with and amazingly fast delivery.
Jas
Hi Paul, forgot to add, there's a few threads dedicated to this subject too;
http://www.skylinesaustralia.com/forums/topic/327936-m35-bov/
http://www.skylinesaustralia.com/forums/topic/314048-m35-strange-exhaust-noise/
If you don't have the problem though, i wouldn't bother replacing the BOV.
In my case, fixed the issue instantly & i'm as happy as a pig in mud.
^^ this.
If it wasnt playing up I wouldnt have done it. Might have been cheaper to get another stockie, but who knows if that would have the issue too.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
