Im running Aarons old Turbosmart compact, with the stiff spring it still runs fine. I only changed as the stock one wasnt coping too well at over 30psi, even with the grub screw mod.
How is my stock one going Jase? Prince Skyline had the same farting problem so I gave him my stock one to try. Seems to be a common problem.
Got the cruise sorted, finally! Works great, thanks to Leon for sorting and all the help. Probably just need to turn the gain down at some point I think.
Also got the other fog light switched over to spotlight with HID. Looks great, and very happy to have matching lights again. Looks much better matching. Was thinking about adding squid rings to fill the gap between old and the smaller new lights, but can't find anything with the right ID. Don't think it matters for now.
Next project is fuel pump while I wait for the SuperPro bushes and camber bolts to turn up.
Can't wait to get a wheel alignment - pulled one of the rears off on the weekend and the inside edge is all feathered. New wheels and tyres go on as soon as it's been aligned! :banana:
Took some shots of the spotlights tonight, just as it started to get dark. :thumbsup:
I actually like them now, I think I prefer the slightly smaller lights.
You can see I still need to finish cleaning the silicon...
Lights on!
For those interested, the lights are Narva 100mm spotlights with a HID conversion kit I got on ebay. Pretty easy to mount in the end, you just have to remove the Cibie glass so you can reuse the mounting hardware. Narva lights were ~$70 for the pair, and the H3 HID kit was ~$35.
My only issue now, as per the other thread, is Nissan don't allow the fog lights and high beams to be on at the same time. So according to Iain I need to wire up a diode and relay to fix this. Can go on the list!
They look great when on Ryan - nice job. I'm tempted to convert mine. Do they throw out a decent beam?
I can't think of the last time I actually used mine as fog lights, but Murphys' Law states that as soon as I change them I will need to travel a long distance in the worst fog in living memory.
Not yet - still have to work it out. Iain thinks he knows, I'll see if I can work it out.
I did this for a set of foggies on a Liberty years ago. I had a 2 position switch that allowed me to either a) lock them on, regardless of headlight position, or b) have them turn on & off with high beam.
That made them a practical addition. What would annoy you, & oncoming traffic lol, is if you had to dip head lights & also turn of the driving lights as a separate action. I'd be happy to play around & help out with a circuit.
Seem to Leon, but I haven't had a chance to try it out in the dark yet. Will do so this week. A single was great though, much better than the foggies.
That was my logic too... too hard to find a new fog light, and I never used the foggies. Spotlights are much more practical.
If you can figure out a circuit, that'd be great. It's not that high on my list at the moment, but the switch idea appeals.
Use the high beam 12v+ at the light and run that to a relay. So that when you turn the head liht on the relay will turn on. Then on the contact run a new circuit from battery (fused) and to a on/off switch and then through the relay contact and then to spotties.
So the spotties will only work when on high beam and then you can turn them on or off via the switch. Even if you leave the switch on the spotties will still turn off when on low beam via the relay.
That's all good, except if you want to run the spotties without high beam (or any head lights). That's why I previously used a 2 position switch, with the other position simply operating another relay to turn them on constantly. Of course that was before everyone started running with fog/driving lights on during the day & the police started cracking down on such use. To keep it nice & legal, maybe best to stick with only on when on high beam....
On the weekend I checked over my adjustable arms (camber/traction) and dropped the suspension 2cm allround. May drop it further, but will do a week of driving and go from there.
post-58831-0-06660300-1329199764_thumb.jpg post-58831-0-38074800-1329199802_thumb.jpg
Also removed the rear wing and debadged the boot.
Fitted Blitz LM panel air filter... :blush: The old K&N looked horrible.. After serving good time in the R33 and now the M35, time for a clean and maybe retirement...
Thanks Jason :thumbsup:
RDA slotted discs and HPX pads go in on Friday as the old girl gets serviced... Looking forward to non-shuddery brakes...
Out of curiosity, what did that set you back?
ask boostin imports in the trade section, they've usually got pretty good prices. mine were 799 for all 4 (different car though)
Replaced the bottom headlight bulbs, but now going to look into what the top ones are. Tomorrow aiming to get the new LED parkers in, and hopefully run the wiring for the new fuel pump, if not get it all finished.
Got in it today though to find the air con blowing hot air for the first time, and three of the four windows won't go down. I think the thermo fan is buggered.
Also picked up a small trans cooler today to use as the power steering cooler. Think it will be ok, hopefully won't be too small.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
