Here's what I've done to the car since purchase...
Hdi FMIC, Transgo shift kit, Brembos from 60th Ann 350Z, custom 3" exhaust with Scotty's dump pipe, uprated sway bars from Selbys/Fulcrum, PWR transmission cooler, LED daytime/fog lamps, air horns above FMIC.
Still to do - bonnet strut kit (no garage and it's been raining constantly in the Mountains), EBC, possible info meter and double DIN DVD/CD + reversing camera + navigation. Considering a Scheel drivers seat I've had since 1988, big wrap around shoulders and still in good nick. It's migrated from car to car.
Some new wheels to replace the T7s.
Attached is a photo taken before the foggies and transmission cooler.
More photos to follow.
Anychance you can post a pic of the led day running lamps?
Been thinking about fitting some but can't find any that look good so far and where to fit them.
I'll get a shot of the lamps this weekend. It's raining again and I hate going outside in it. :ninja: Hopefully, if there's a break I'll sneak out and take a photo...
BTW, I bought the lamps on E-bay from a seller in Sydney. I studied so many of them, my head was spinning. I didn't like some of the chinese ones on offer. Got burnt a few times on
some purchases not being what they seemed.
Here's hoping there is no more rain for a while.
my DRLs are better :P
IMO i think they would look better next to the headlight unit, in a semi upright position.
what do they look like while on?
Pics of yours also then please ?
Edited by slippylotion
Lol don't worry Paul, he's talking about the DRLs on his stupid Vee Dub.
Nice job Russel, although don't think that'd work on mine as I've got the Aero kit. Not keen on hacking up the good mesh to fit them. Won't work as well as it does with your horizontal lines either.
Ah, so he's cheating! He had me going.
Yep. Wanted DRLs so bad he bought a Beetle with them preinstalled.
You've got the aero kit right? Where were you thinking of putting the lights?
Yeah I have the aero. Not sure where I would fit them. Ideally I'd like them under the headlight but I can't see that happening.
You'd have to use the LED strip lighting, and then you'd look like you're trying to rip off Audi.
LOL @ Iain - his car's not even a "proper" VW. :P
Oh, and in regards to factory-fitted LED DRLs, I have to say that I think Audi are amongst the very few manufacturers getting it looking right.
lol they are in denial, VW has owned AUDI and Skoda and SEAT for ages. they have all used VW engines for years too. Its the reason why i got a Skoda. I got a Golf GTi that is more practical, cheaper and had more options as standard. same trim on a golf would have gone over 50k.
I know they're all owned by the same company and use the same engine blah blah blah...
But I'm pretty damn sure the build quality on an Audi is better then a VW, or heaven forbids, your Skoda :nyaanyaa:
Reading the reliability survey don in the USA I am not so sure you are right about this.
VW rated 56th out of 60... :whistling:
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
