This is what I'm aiming for, what's your setup?
Autech 260RS
Stock bottom end
Stock FPR
R34 GTR turbos < Terry's old turbos :whistling:
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
Gutted cat
N1 oil and water pumps
Greddy oil cooler kit
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
yep, the jaycar kit, works perfectly. Just tapped the speedo wire at the dash and hid the box up behind the hazard light switch. It's been in there a while bu I had to adjust it because I've changed rim/tyre size recently.
Nismo dash is the main reason I had to fix the speedo. A big digital speedo is just annoying when it's wrong!
Drunkan, you've fixed the speedo, but the tacho looks like the reading is out of whack too. And what wheels and tyres are you running now? Pics please?
Oil change (my last bottle of GW Sougi s6000), and a yearly inspection of the turbo oil feed banjo. Was enlarged to 1.5mm last year.
Looks like I'll be changing to the new GW SYN-X 6000 for the next one.
I checked my banjo this week and it was squeaky clean. I didn't enlarge the size of it though.
Edited by slippylotion
Whether or not to enlarge seems to be a personal thing; to each his own. There's no question; it's cheap insurance to remove & inspect.thumbsup.gif
Autech 260RS
Stock bottom end
Stock FPR
Walbro fuel pump
Power FC
AVCR
Z32s
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Fujitsubo Cat back
Gutted cat
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
Nice Build, bet its great to drive
I was just wondering how the Power FC goes with the 260RS, Im assuming you used the one specific for the R33 GTR/RB26
Did you have any issues getting it to work, does anything not work as its meant to.
from what i have read it "should" work fine in the stag but i have not asked anyone who has actually done it,
Thanks
Thanks
No problems here
Yeah mate that tacho is wierd....lucky mid 90s LCDs had such crap resolution. It consistently reads 500rpm high, not like the speedo that was a % wrong (ie wronger the faster you go)
I've got R34 GTR rims (finally clearning the brakes properly) and 255/40/18 Federals. No pics it's too wet :P
Also fit Z32 AFM today, total fail. SOmeone has played silly buggers with the Z32 AFM curve on my Powerfc and it's not running properly. I'll probably put the standard AFM back on until I can get a tune.
Thanks
I am running a R32 GTR PowerFC and the car runs fine, an R33 PowerFC would also work.
I Run a R33 PFC (on a R33 RB26) with almost identical setup, minus the inlet and hard piping kit, but I'm still around 20kw short of your power. Guess its time to order those Z32s and the Greddy kit then... thumbsup.gif Good to see whats possible with stock bottom end and turbos...
Found a little cubby hole for a oil catch can today. Hopefully will minimise the amount of oil going out the end of these bloody VQ's. Have to go to pirtek tomorrow and get some real hose- as usual the stuff they give you is massively shit.
you need one from an RS with hicas, or an ARX. but only vq25det
Not true. Pretty sure Craig said 350Z 5MT rear diff, but I'd have to check.
I think the VQ25DD front diff is the good one though, haven't double checked yet.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
