Not true. Pretty sure Craig said 350Z 5MT rear diff, but I'd have to check.
I think the VQ25DD front diff is the good one though, haven't double checked yet.
The 350z manual lsd is the one I run too, different ratio so you will need to source a PM front diff in the same 3.5:1 ratio.
Oh, 5 speed. Ok. Yeah couple of people have gone to 3.5 finals now. Seem happy. Don't know about the cost benefit of it compared to other mods, as the two cars with it done are probably the most modified in the world!
The car feels much more responsive with the lower ratios, it gets the slug moving quicker but the downside is cruising on the freeway at 2,500 revs. Just what I need, less K's to a tank... :rolleyes:
you should have more k's..........less load!
On the fwy i'm in -boost simply because I am not riding the torque converted right down low at 2,000rpm anymore(it used to be +boost).......I am pretty sure I was 10.2lts per 100km's on the way home from Vic the other day fully ladden.
What? Have you read what was posted at all? :)
You can just drop an ARX diff in, no need to change the front one as the ratios are the same.
If you go for the 350z LSD you will need a PM front diff or as Slippy found, a 2.5dd front diff may be the same 3.5:1 ratio.
LOL....my bad!
New rotors, pads, coilovers, coils & plugs, o2 sensors, dash & floor mats, 4700k high beams, personalised plates, alarm installed, front windows tinted, all fluids replaced, and a new tune:)
Should keep her happy for now...
What? Where? How?
cannot tell....I am sure the gaylord will post sooon!
I can say the chase is on again!
E-Manage and injectors WILL go back in mine tomorrow.
Edited by Jetwreck
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
