What Have You Done To Your Stagea Lately?
Hanso
Is it on yet? What wheels did you end up with?
Yes, fired it up last night to check for leaks. Only one was exhaust, but was last join in the cat back so easy to fix. I still have to drop the radiator fluid as only put water in it for the test in case it was a total fail & I lost all the green stuff. Still haven't driven it.
No idea what wheels went in. I wasn't asked what I wanted when I ordered it & didn't know I had a choice. Probably a good thing as I would have researched it to death & then chosen wrong, lol. I just hope it's not too laggy.
Not planning to go through all that again I assume? lol.
I suspect he put the smaller wheels in yours, did you take any pics? We should start a Stagea Hypergear thread and post pics up with power/lag results. I took quite a few...
my wheels r pretty big i mean its laggy but not all that bad , it does come on friggin hard though i think youll be happy with it, especially after a tune itl make such a difference
When does it come on boost? When does it hit max boost?
Is the bigger Hypergear core more expensive and laggy compared to Leon's?
The billet compressor is $200 more, the customer can decide how laggy they want it to be...
It seems to be around 3500 from what I saw, perhaps you can elaborate Marko? Bit hard without a boost gauge I suppose.
I think the sizes are teh ghey. Their staggered for a start, and I think the fronts run a really high offset? like +47 or something?
Yep. Fronts are +47 I think and rears are +15. I thought about getting 2 sets and run the +15s only but too much hassle.
That's pretty good...your old/my setup hits max boost around the same rpm? so its not too laggy then...
Its not laggy at all for the power, just when you compare it to the stock turbo.
Im going back to edge tomorrow for my attempt to crack 350kw with the GTX3071, will let you know how it goes. I wouldn't like to go laggier than what I have at the moment but where is the fun in stopping there? Next goal will be 400. :)
Haha, no Scotty, not planning to do that again in a hurry.
I took quite a few pics and, because I had my original turbo plus the hi-flowed one, I was able to do side-by-side photos. Makes it easy to see the difference.
Good idea re new thread. It's started so you & Marko can make the first posts with your results. I still have some info to gather before having anything useful to post.
Sprayed up the front bar with a can for the trail fit.....also fitted the rear bar up.
Just waiting on the new rear wing now and then it's time for the spray jobs.
I also fitted a new pre-load spring to the Actuator.....back to 14PSI+ launch's! :P
Looking very mean! When the flairs merge in it'll be spot on. Its a shame the former owner of that front bar decided to cut out the stock Kenstyle/Xanadu style grill. Irrespective, it's looking good. Whats the height from ground to the front lip?
Not a mod as such, but I am getting a new windscsreen due to the shit roads I travel to and from work. Country roads FTL.
so I finished the test fit up of the front and rear bars today....looks OK imo! Just need to get the rear wing and maybe a vented bonnet on and the outside is done!!!
