Got me one of these....... :yes: Aha yes I did
Will be a while till its on, as I'm waiting till I see my knee specialist at the end of the month. My last visit was..........lets just say less than encouraging.
Still, I'm soooo happy I bought it. :woot: :woot: :woot:
Nice.....I like it!
Detailed mine, and put it under a car cover again (sigh... I wish I had a garage: that way I could actually SEE the car when its not in use!). Pretty sure I'll be whipping the covers off again soon: the weather's starting to get nice and chilly again!
Had my AFM die on me. Boosting up a hill the power just cut out completely, it would barely idle and wouldnt rev. Fortunately i managed to limp the car home by disconnecting the AFM.
Fearing an expensive replacement was on the cards i soaked the AFM with some contact cleaner, let it sit over night and then tired it out in the morning. Amazingly the engine started up great, idled perfect and drove fantastic. In fact its driving better then ever, i went on a 100km drive this arvo with a whole bunch of blasts of the throttle. Fuel consumption is better and revving feels a lot smoother.
I'd recommend giving your AFM a clean even if its functioning well. Next weekend i'll try cleaning the wife's V35 AFM which is working fine to see if it shows an improvement
Serviced the car last night, oil (trying ULX110), filter, replaced belts, air filter and spark plugs (NGK)...... My car had a slight miss under big load and my economy was pretty average (6/7km per litre) One of my coils was covered in oil (the side that I had my rocker cover gasket changed under warranty) .......needless to say I was pretty impressed. Also I had 3 different kinds of plugs in the car NGK Denso and some wierd jap one WTF, all finger tight (washers on bottom of plugs werent even crushed) :unsure:
Wat? Your kidding, dealer serviced?
Thats a job I would be doing myself, so you can check the plug tubes are clear of oil. They wouldn't even tell you by the sounds of it...
I service my car but haven't done the plugs until now.....I am a qualified mechanic, but when the car was in warranty period (3 months) I got rocker cover/ srs light/ swaybar links/ disc machine blaa blaa done, As I figure I am paying all this money, I am not working on my daily when I don't have to.....
Also when I got it onto the hoist i have noticed I have a couple of very bald (camber) rear tyres and most of my bushes in the front need replacing, so at last I have a reason for changing wheels and tyres instead of the chrome gayness. Will also be needing bushes ASAP
Now just talking to the guys that did the warranty work. They did the outer rocker seal and the inner isn't serviceable (around the spark plug tubes) and you need to buy a new rocker cover or sealant the shiz out of it and cross your fingers? I take it they warp?, anyone had this problem before? Someone has had a go at the sealant already (as one of coils also had sealant on it).....
I did it but I wouldn't recommend using too much sealant in there, probably best to find another rocker cover, new if possible, but they were over $200 I seem to remember and would have to come from Japan. The plug tube seal isn't replaceable.
Awesome.......I wouldn't bother with a second hand rocker as mostly likely would have/will warp.....I am getting a few quotes on rockers covers now..... but this is money I would rather be spending on suspension or exhaust or on my race car......
Will report back with quotes
Edited by MOUTH
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
