I wouldn't bother mate. If you are dead serious about power, then get a different (3inch) muffler welded on the end and keep that Muffler. But I would suggest if you don't have a high flow turbo, piggyback, etc etc, I don't think the exhaust will be that big a deal. I'm only going by the Mods in your Sig. Do you really want it louder? Doesn't seem like it has any muffler to it anyway!
Fitted Tein S-Tech springs in my series 2 RS4S yesterday. Was hoping for the 1.5inch drop that they claim but it's only dropped about 10mm in the front and practically nothing in the rear. Just hoping it'll settle down a bit over the next couple of weeks with driving. It's definitely stiffer though.
Went to drive it for the first time in 2-3 weeks, found the battery was flat.
Put it on charge for about 6 hours, checked voltage, 1.5v. Pulling it out and putting it on a deep charge for a couple of days to see if it'll be ok, since it's only about 6-9 months old. :(
just fitted a new rack end on passenger side, bought a new pair from ebay (link from Dale)
http://www.ebay.com....#ht_1749wt_1037
after fitting it and drove the car, steering was very loose that when i came out to check the wheels. the left one (passenger side) had a toe in about 5-7 degrees :angry:
after a closer inspection, the new rack end is actually longer than stock one (refer pic) so had to cut off to roughly the same length, now just need to do wheel alignment
thought to share this so if anyone else needs to change the rack end to the same ones i bought, better measure and cut 1st
I had to remove those two black strips at the edges of the tailgate lid & the spolier screws into the metal beneath where they sat.
Then it just basically sits on top of the black plastic trim that the centre brake light is part of (with help from a bit of double sided tape)
I'll take some more pics when my wife gets back from the shops with it. :whistling:
Dyno'd the car last night. Car feels awesome to drive. Less boost made more power.....18.5psi ftw!
240killa wasps....car feels strong right through the range.
Jez the tune is awesome....and the f$@ker starts hot or cold for the first time in a long time.
Excellent buddy :) glad ur happy.
Sorry about the dyno sheet. Damn dyno restarting on me. Forgot to input ur details back in correctly.
Haha i underestimated ur car. Wheelspin on the 1st pull of the night. Was exciting. We need to find a way to lock it into gear though. Was hard to tune below 4000rpm. Will have a play on the road when u are ready
Limp mate, the kickdown is just to keep you on your toes. :P
The torque converter lockup solenoid needs a 12v voltage on it for a start...
I made up some speaker mounts for the M35 to fit some Alpine Type R 6.5" front splits and 6.5" rear 2 way coaxial speakers. Made them out of some structural ply I had laying around. These will finish up with the speaker sitting close up to the door trim as the factory speakers do. Will finish them up and install them over the next few days. Pretty happy with the result so far.
Edited by slippylotion
Haha sure did. Foot flat 100rpm too early and it
Jumps down a gear.
With the lock up how well does this work? It would be good to do this just whilst tuning then we can put back to standard
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
