Most likely you've ended up with a reasonably bad boost leak....do you have a boost gauge, and if so what does it show.
Go back around the whole job and check every hose is seated square, and every hose clamp is tight. The easy way to check a hose clamp is to push hard on the screw part - if it turns on the pipe it is too loose. But even if they are tight, the hoses have to be properly seated on the pipes, ie square on and good overlap
Howdy,
thanks for all your input!
I Double checked the hoses and een had a mate of mine come by after I had installed it yesterday to ensure everything had been connected properly. No problem.
I spent all day wiring up a boost guage (Apexi mechanical) and finally got it to work.
on idle: -0.5 to -0.6
driving: -0.7
OK, so im assuming it should be idling on 0?
Howdy,
driving: -0.7
No, that sounds reasonably normal. Engines are almost always on vacuum (ie less than 0) because they suck air in. the more you open the throttle the more air they suck so the more vacuum you'll see. But with a turbo car of course, as it comes on boost it moves from vacuum (negative) to boooost (positive), but only when the engine is under load.
Unfortunately that means that you need someone to watch the boost guage while you floor it for a while. Up a hill is best because boost builsd more quickly and the car accelerates more slowly.
OK so took it for a drive today and found a steady incline.
During acceleration, the gauge hovered around 0.5 and whilst in 2nd gear at around 3000rpm onwards I could feel the car 'stuttering'.
Thoughts? I think this is getting a bit too over my head for me.
Finished stripping the heads off today and cleaned up the block ready for the new oem head gaskets and L19 studs. It all looks pretty clean in there now, hopefully an oil flush will clean out any residual coolant I haven't managed to get to.
Luckily it looks like just a split head gasket...
Today, i pulled the glovebox apart to investigate what sorts of plug connectors the DVD rom's got, and found the glovebox light was blown. Replaced the bulb, all good now. Also cleaned the pollen filter. Still not able to get the reversing camera wired up as the camera wont work for some reason(ntsc). Also gave it a wash. :yes:
Gotta love how E85 keeps the pistons and combustion chambers clean.
Is that the knock sensor in the valley?
yeh i asked him if it was yesterday and yeh apparently it is the knock sensor
What's this Aaron? A non random post? That's not like you...
Yeh Paul, the pistons were only a little coated in carbon, a light spray with gasket stripper had them polished like new.
And yes, that is the knock sensor, not that the Fcon cares about it much.
In Pic 1 is that a cast mark on the engine mount or a crack ?
could the issues that I have been experiencing be a coilpack issue? I remember experiencing something similar with another car of mine years ago..
Just a casting mark.
It sounds like it, Stuttering is usually either plugs that are fouled or coil packs breaking down. It could also be low voltage/bad connection in the coil loom. Without more information about the car's mods and power level its hard to guess the cause.
Studs turned up today, all went in well bar one, it looks like the thread is a little chewed. :verymad: I will have to buy a long M11 x 1.25 tap tomorrow.
I also match ported the upper and lower plenum halves and throttle, the head ports looked pretty good but the runners were all over the place.
Nope. lol, I don't trust myself around the valves without removing them and I don't want to get a stray piece of alloy in the oil galleries. Do you think it matters? The area of the 6 ports is a crapload bigger than the turbo and wastegate. It should be fine mate. There is definitely a heap of material I could remove there though.
im gonna talk you into it lol..
i think you should.. why not its all apart.. just be a true hampton parker and shove a sock down there and vacuum it out before you take the sock out lol
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
