+1 pm with price if you want.
And maybe a drum of 3000 for the daily too.
I can get a price for that, I'm possibly going to get one of that too; I reckon it might be a bit over $100.
Cool. Is that from a chain parts store at retail or a trade only supplier?
Their head office is not far from me; so it was at their main warehouse.
I'm sure you'll be able to get them from an oil wholesaler though.
I got the passenger seat fitted today and cleaned the interior quickly, it's got to look its best for the dyno tomorrow. :)
Also a pic of the stock looking engine bay. The cover makes a difference.
Looks comfy in there mate!
Some black silicone joiners, some satin black paint; factory spec.
I never found the engine cover fitted particularly well once the spacer was in - did you put some risers on the front bolts or just encourage it to bend a little to get some purchase on them?
This weeks Stagea related activity appears to have been borking my turbo. :(
Seems last weekend's cruise was a bit too much. Weird; because I was taking it easy too...
Onward & upward eh? :whistling:
What's the plan then? Hypergear?
If only you had somewhere you could take it to do the turbo work for you... :whistling:
Sounding a bit suspect is it mate?
I ditched the spacer. ;)
Ouch, How big are you going?
Whatever you do, dont go to that Stagea HKS bro garage joint. (heard bad things). lol.
Probably not; been talking with Craig, and I'll be going with something that he's recommending.
He's driven a lot of different combinations, built by a bunch of turbo builders; so I trust his judgement.
It has a very strange whine emanating from it now; and that's in addition to the standard whine.
Still boosting fine, and doesn't seem to be rubbing; but who know's how long that will last.
Had to happen eventually; I reckon it's been living borrowed time for a while now. I'm currently at 103,000km (plus whatever the mandatory haircut adds) so it's done ok.
Unfortunately, I don't think I'll be joining the powah war. :/
I really want to keep the response close to the stocker; so it's going to be small.
The cruise the other night just reinforced to me that I don't want a lagmaster; it's really nice with the handling it has, it's devastating point to point on a windy road.
I don't want to lose that; I just want to have the really good midrange of the stocker with maybe a bit of potential down the track for a handful of extra KW's IF I choose to go a bit more boost and aftermarket management.
That's still a way down the track (if at all) and I don't want to regret going too big in the interim.
I have a 170rwhp, 300km/h bike that makes any car look stupid (does 164km/h in first gear), so I don't need the car for my speed fix.
I've heard bad things about that workshop too; have you seen the bloke who runs it? :P
Edited by Daleo
YES! I agree Dale :thumbsup: (but you already knew that, lol).
just a suggestion i had a strange whinning noise that i thought was the turbo lacking oil on startup would last a little while and then go away. it was like a nasty queeling noise and eventually i traced it down to the belts on the front of the motor needed some dry lube, WD40 done jack sh*t but helped me find it as its not easy to get ur hand past the clutch fan to lube it up.
dont know if this helps but anythings worth a shot!!!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
