just a suggestion i had a strange whinning noise that i thought was the turbo lacking oil on startup would last a little while and then go away. it was like a nasty queeling noise and eventually i traced it down to the belts on the front of the motor needed some dry lube, WD40 done jack sh*t but helped me find it as its not easy to get ur hand past the clutch fan to lube it up.
dont know if this helps but anythings worth a shot!!!
Thanks for the suggestion mate, I know exactly the noise you're talking about Theo; but this is definitely appears boost related.
Basically as soon as it goes positive manifold pressure; the whine starts. It overlays the normal whine that the turbo has.
Sounds like the t3 exhaust gasket, I have had a few like that. Could be the front wheel rubbing though.
Need a replacement stock turbo? It could be a better option if you don't want to highflow...
Hmm, I don't think it's a leak; I'm going to get it on the hoist and stall it up, we should definitely be able to see/hear a leak if there is one.
Frankly, I'd be happy to stay with the stocker; but who's to say how long a second hand one will last? Are you talking about the one you were running on yours in between setups?
Feel free to PM me if you have time mate; it might be a viable option. :thumbsup:
Edited by Daleo
I don't mind Lainy, I like talking to other people. With the car at my house I should be able to get parts shipped quickly, not taking 2 or 3 months like 'other' members. :P
lol.
lol.
Yeah that Lainy guy is a bit of a member... :whistling:
i got stranded today the damn battery in the key/remote went flat............ unlocked the car with the key and the alarm went off and then tryed to start it but the alarm wouldnt stop so couldn't go anywhere untill i got a new battery in the remote. very convenient when i was at the dog park, luckily a mate lived close by and we ran up to the shops and got a new one.
so for anyone needing a battery the part number is CR3020.
Hmm, I think I asked that Lainy bloke for a part to be measured ages ago, just after he got his hands on the wreck, actually. Still waiting for a reply...
Bloody Skoda drivers! :rant:
Oh yeah, I got my clutch replaced on Friday - out with the supposedly heavy duty Exedy, in with a Nismo twin-plate. Getting used to a new clutch and re-acquainting myself with driving a manual at the same time, after roughly 5 weeks of rolling around in only autos.
Saw your pics Nick; you must've been pissed to find whatever that thing was, that was masquerading as a Heavy Duty Clutch!
I'm assuming that was a workshop job? Good to see you've got what you paid for this time.
How are you finding the Nismo clutch? I was going to go for the coppermix single plate when i did my manual conversion, ended up being a bit too expensive at the time though.
Nah, I bought the last clutch myself, Dale, and had Unigroup install it.
Sourced the Nismo myself again, but Unigroup were flat-chat and I wanted my car back, so I got another local mechanic to do it, about 2mins drive and in the same suburb as Unigroup. We deal with them a lot, so I know they do good work too.
Oh, and here's the supposed "heavy duty" Exedy job - less than a year in the car:
It's butter-soft, Brian. Loving it so far! And no, it wasn't cheap, but they do come with a matching lightened flywheel which kind of makes up some of the cost.
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
