Changed cabin filter and ordered pass side cam cover gasket. I bought a repco carbon activated replacement filter for $25.
I bought the carbon style cabin filter and still get a lot of fume smells in the car from other cars, do you guys get the same?
Edited by slippylotion
Are you sure you aren't smelling yourself? :)
I assume you ordered the cam cover gasket because it's leaking oil. That'll slowly drip onto hot things & is right below the air intake.
That was the big indicator for mine & no, never noticed it before.
It could be me :yucky:
Yeah I noticed the gasket starting to leak a tiny bit so thought Id get straight onto it. The smell I get is exhaust fumes not burning oil. Ill check tomorrow that I put it the correct way up, The arrow should point up yeah?
Does that mean you'll have a spare once you're all done?
An unknown donor sold a busted up turbo to a guy in Brisvegas. He generously lent it to me to be hi-flowed & I sent mine back which has now made its way to Dale.
Afaik the spare is to be offered to whoever buys his car, but there must be a few units around that could be used by the community for these swaps...?
Beat me to it Leon; As you said, I was very generously allowed to borrow this unit by it's owner, so I can't speak for it's ongoing availability.
Ah, I see.
Is there a particular reason most people opt for a high flowed stocker over a new off the shelf unit? Simply ease of fitment?
Or does the M35 have a unique flange design or something like that?
Pretty much; both air intake pipe and hot side pressure pipe are bolted to the housing, and have a very tight clearances on their pathway through the engine bay. Also, you'd likely end up having to go custom on your dump, depending on housing v's exhaust flange orientation.
So there's a decent bit of fabrication to do just to get something different to fit.
Scotty would probably be the best bet for some photographic evidence on what there is to deal with.
For the power I'm after; it's not worth the arseache of refabricating all the pipework.
The starter motor decided to die (at the mechanics??) the other day... After searching around on here and going with peoples recommendation that a RB30 VL starter motor would fit... it DOESN'T! Luckily Repco do returns...... Ended up servicing my old unit (Discovered the brushes were worn out)...
My mechanic reckons its a bitch of a job to get it in and out for anybody looking to do theirs
Nismo extended wheel bolts, 10mm spacers + wheels
Derale transmission cooler and trans service
Gave it a wash (finally).
Next weekend = 50,000km service
Getting there, slowly :)
Where are the pics though?!
where did u get the extended studs from cam? and how much? interested in getting some
Mine died last week, I was told a vl turbo one would fit (not a NA)? I went for a new Mitsubishi for rb26. $350.
Was a 5 min job to fit once the intake is off...
Servicing the old unit was 160 which wasn't too bad.... Repco didn't have any of the Skyline models listed (you think they would right)?
Anyway all good now, I think the RB25 may be harder to work on due to the i/c piping etc doing laps above the engine :down:
Extended studs I purchased from RHDJapan.
2 sets of these although they do 60mm as well
http://www.rhdjapan.com/nismo-long-hub-bolt-50mm-5-lug-front-and-rear-14-3-50x10-55526
You did it from the top????
It's a 15min job from underneath.
Doing a cooling system flush after finding this crap
Ive got no crap in the oil and its not over heating so hopefully just poorly maintained and not a head gasket.
Its got the same sort of texture as mud and its brown...
Edited by theferris
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
