Looks like what happens when only tap water is used instead of a coolant/demineralised water mix.
Thanks for lowering my heart rate a bit, only had it for a week, and I have to start a gearbox swap on my Jeep.
When I drained it there was only a very faint smell of antifreeze, like it had a bottle of premix put in then topped up with tap water.
Coolant also inhibits corrosion, so first step would be to thoroughly flush and then fill with appropriate coolant/demineralised water mix IMO.
Thats the plan, I think Ill run through some coolant treatment stuff before aswell for good measure. Do the thermostat at the same time.
Also - take some of the smaller coolant lines off, and the heater core lines and flush them through - you may find a lot of crap floating around in the wee little areas and corners of the system. I flush my heater core out when I change coolant and usually some shit comes out.
Its important to get good flow around the system because certain valve thermostats open and close based on it.
Sent out back up turbo for rebuild today; should see it back early next week.
Also, finally reassembled and fitted my R34 GTSt calipers and rotors! :banana:
These were stripped and bead blasted, then coated in a 600deg ceramic coating; that is impervious to chemical and brake fluid attack, so they should be near on indestructible, and look great for ages.
Rotors were basically brand new OEM Nissan, and since they're a nice high carbon content steel, I decided to use them, so these were also bead blasted, coated, then sent out for machining and slotting.
Pics;
For anyone thinking of using the 310mm R34 GTSt brake upgrade; you will need to cut away or remove the backing plates from the front hubs; as they foul the rotors.
Not a big deal, but you'll need to be handy with a grinder to do a neat job.
Also; I remove the double flare seat from the brake line thread, this means you don't need to butcher your banjo's to fit the OEM lines. You can just use a small ezy out, or a self tapper to yank it out.
I had expected them to be a nightmare to bleed; given they were completely dry internally, but they were probably the easiest brake bleed I've ever done! Only took around 5 mins a side; and the pedal came up great.
Still bedding the unknown original pads ATM; and I'll be using a fresh new set of Remsa's from GSL Rallysport by the end of the week, so I'm not sure what the power will be like, but they certainly seems decent so far.
Edited by Daleo
Looks great Dale! Stone shields are for pussys anyway :)
You didn't want to wait till you got new pads to bed them in? I heard that brakes like having the one pad compound applied to the surface. Brakes are a dark art to me - so many different opinions, I dunno what right. There is a lot of BS floating around out there I think.
One thing I haven't got right, and effects things, is the wheel nut torque can cause shudder and warp in discs. Sigh. Fark I hate brakes.
The pads aren't a big issue really; I'm not actually "bedding" these pads (heat cycling to transfer pad material on to the rotors) which is what makes the brakes work properly.
The friction of the pads pressing against the rotor is not what makes brakes work; it's the grabbing and breaking of bonds between the pad material deposited on the rotor surface and the pad itself.
You are right about the incompatibility of differing pad materials; but 30 km of driving, with maybe 4 light brake applications isn't going to be an issue. You really need a proper heat cycle bed in, and a few hundred kays of driving.
I've never really heard about wheel nut torque being particularly critical; but a wild variation might be an issue. I've never used anything but a wheel brace or a breaker bar & socket.
The one that does fool the younger players, is the effect a dud wheel bearing can have; brakes will develop a shudder over 5000km and rotors need machining; only to develop a shudder after another 5000km.
The other is the fact that discs rarely actually warp; the shudder you feel is almost never a disc with axial runout; it is almost always an uneven build up of pad material on the rotor, or a hard spot on the rotor that has a different coefficient of friction to the rest of the rotor.
This can also manifest in severe chatter when attempting to machine the rotor.
Dale, what specs are you getting the turbo built to?
I've ended up going with the tried and true "Sierra Stage 2" which ironically; is almost identical in wheel size to a 2871.
I spent a good piece of time today speaking to the turbo builder, and looking at a number of different impellers and turbines to demonstrate his viewpoint.
I was pretty sold, as he was the only one that would actually justify his selection; rather than just "This is what we use."
The main reason I didn't end up going with the 2860 was the fact that he doesn't believe there is enough material in the housings to guarantee that it can be machined accurately to take the 28 series core. This is why the common choice is the 30 series Garrett core; even though for most people, it's a bit big for good response.
At the end of the day I'm satisfied it will do what I want, and I've essentially made it so I'll need to do a bit of tuning to get the best out of it; which is what my tinkering mind wanted to do anyway.
That, and I will now be able to make lag based excuses about why my car can't win a drag race. :P
TL;DR?
I know SFA about brakes, and even less about turbos...
Great post Dale. I read the same thing regarding warp vs build up. I have certainly suffered the build up before but thankfully seemed to have wiped themselves.
It was an IS200 that was really fussy about nut torque. Had new discs on it, only to warp quickly. Once we dealt with that and went factory on the torque via wrench, was all good.
I'm really yet to give the sumitomos/PMus a good long hammering in the Stagea, to see what they do when really hot, but they are certainly a good upgrade over stock.
Stage 2- that's the same as what is on andy's old arx I think. Worked well on that I believe.
Dale, now I know why you sounded confident about getting the turbo back early next week, lol.
Looking forward to the first impressions report when you get it in.
Edited by Commsman
finally got around to purchasing some injectors for my build. bought a set of Sard 650cc injectors at a really good price :D they should go well with the walbro i think. got a turbosmart dual stage boost controller in, just not hooked up yet, need to get a z32 afm, and purchase my turbo, then into DMD Tuning for a nistune for a hopeful 280rwkw.
Maybe the IS uses a thin flange on the hub; this might account for the fussiness regarding wheel nut tension.
The Sierra is what Andy was using, not sure if he was using the S1 or S2 spec. Also Craig thinks Spoolin has the same. I guess we'll see.
Also having the rear housing ceramic coated once I get it back.
Lol, I'm pretty lucky being so close to a couple of turbo specialists; at least I can save a bit not having to freight it all over the place.
Craig was also very helpful; listening to my mad ramblings over the last few days, thanks mate.
what turbs ya going to run? Auto/ manual keep us posted
Still kicking man, trucks going well, needs to be louder tho, the twin 4" pipes are too quiet. Lol
You sold the rx4 yet?
yeah not sold yet only advertised them in sa section eoi really want them to go to a good home. and between the ute the stag and baby number 3 on the way i got enough on my plate with out contemplating the 4s
i have an rs4s, so factory manual. im pretty much sold on a hypergear ATR43G3 with a .82b internally gated housing. i have an r33 aswell that i went all out on last time, and im sick of the defects, so im trying to get as much out of the stag as i can and keep it as stock looking as possible. i should easily make 250rwkw @ 18psi with what ive got according to DMD tuning but ill wait and see i guess, if it falls short, i might look at getting some poncams put in it.
my main concern atm is my clutch, its feels great but im not sure if its stock, i might have to try and have a look, it had a few mods when it came to me from japan, so im not sure what its got in it, if i need to replace it, im looking at an NPC organic single with flywheel.
Edited by OMY31T
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
