What Have You Done To Your Stagea Lately?
Hanso
I don't know if your mate is my mate (Chris from Craved Coatings), but he did the radiator, oil cooler and sump on my race car, it definately ran a degree or 2 cooler afterwards. When you are pushing everything super hard, every degree makes a difference.
Duncan, my mate is in Penrith also; but it's not Chris. I've seen the Powdercoating that Chris does & his work is amazing, my mate is only just getting in to the decorative coatings, and there's a few ceramics (the polished finish ones) he does that Chris can't do.
You're dead right though; at the limit, every little bit makes a difference, and there al all kinds of coatings, heat shedding, heat retention, heat reflecting, anti scuff, lubricant holding, lubricant shedding; the list goes on and on.
I'm really going to have to investigate these coatings more because I drive my nimble beast at the limit every time I take it out.
LOL.
Just ordered some piano (castor rod) bushes. Pick up Saturday. Getting the offset style.
They're going to get your Baby Grand handling like a demon! :woot:
The creaking and clunking tune it makes now is horrible. Seems everything is coming at once ATM. Attesa pump, cam cover seal and piano bushes. That's three so hopefully good for a bit now ?
Edited by slippylotion
Update; Turbo is out now. :banana:
post-61153-0-47778500-1343300106_thumb.jpg post-61153-0-45897300-1343300163_thumb.jpg
Truly there has never been a better example of the right tools for the job than this job.
After wasting hours yesterday with the heatshield bolts; we bought two Snap On spanners and a 3/8 drive 10mm single hex socket. What couldn't be achieved in several hours; removing the heatshield was completed in around 20 minutes. This cleared the way to finally free the turbo from its home.
I've also modified the offending heatshield so that the remaining section can be refitted; all the bolts can now be accessed, and it can be completely removed in about 2 mins.
In other news, the exhaust housing, dump and mid pipe have now been blasted, baked, blasted again, and coated in the thermal basecoat.
It has now been baked out and is cooling. The external thermal coating will be going on tomorrow, with the internal coating for the exhaust housing and dump to follow.
post-61153-0-82551900-1343300963_thumb.jpgpost-61153-0-60004400-1343300888_thumb.jpgpost-61153-0-53352900-1343300874_thumb.jpg
The coating goes on a greeny colour as seen on the Dump & Mid pipe; then dries almost white, as seen on the exhaust housing.
Once baked; they are almost completely white.
Edited by Daleo
I can get some numbers for you tomorrow; they're about $55 each though. I'm planning to marry mine.
I didn't take a pic of the heatshield, but I'll get one tomorrow.
Sweet, thanks. Should start getting the tool kit in order for when the inevitable happens.
A couple of pics of the exhaust side of the new highflow compared to the OEM core.
Edited by Daleo
What is the gap like on the rear wheel from the housing? It looks to have huge clearance, is it just the photo?
That's only a baby turbine, should be responsive. Good choice buddy. :)
My special tools... Cost : $0 ;)
The clearance is reasonably tight; I think it's just the pic, there's a couple of funny reflections & shadows. The coating will close the clearance down slightly too.
I'm hoping so; we'll see in a few days.
Trust me; if the Snap On truck hadn't been in the corner, we'd have been doing the same. I already had one long spanner made up.
Paul, I took some measurements today, but I left everything at the workshop.
I forgot to mention, I received these springs in the mail today, should hold the gate shut till around 26 - 30 psi. :)
Install tomorrow along with the thermo fan controller.
Anyone for a 3.5 inch dump?
And the new torque converter, packing triple Pathfinder lockup clutches. Not sure when I will get time to drop the gearbox again...
It'll be interesting to see if the new converter with (more/better?) clutches can take the punishment.
Sounds like you've got some fun ahead. :thumbsup:
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
