What Have You Done To Your Stagea Lately?
Hanso
2 1/2" Suction pipe tacked together for a trial fit tomorrow, prior to purge welding.
Now we get to see how accurate my fab is. :whistling:
Nice and tight down there isn't it, I assume that's why you went with 2.5 inch?
Yep, sure is. Getting your 3" version through must be a good job.
I'm running it through the path taken by the original, and it's only about 6mm wider at the critical point than the OEM one.
I was able to use standard 316L mandrel bends, and I've got a pretty straight shot at the compressor wheel. The inlet on the compressor cover is 2 1/2", so it shouldn't be restrictive.
I've also hooded the Blow Off inlet merge into the suction pipe to hopefully avoid any reversion issues.
The piece I'm looking forward to changing is the section before that, but I don't have any more material (or time to be honest) atm.
Make sure you take some pics Dale - love to see what you've done. Could it be the prototype for a future manufacturing run...? :whistling:
Edited by Commsman
You all realise you will hit airflow cut with the intake done right? Read 'close up view of the windscreen" lol.
It's all downhill from there... :)
Haha, yes, it's a slippery slope - one thing leads to another....
Will do; lets see if it fits first...
Yay! Random windscreen headbutts eh? I love surprises! :woot:
Downhill or uphill? I'm hoping a little bit of bad might lead to some good. Might need to wait for my wallet to recover.
Mine's sitting at the tuner, waiting for tune: can't wait: going for a nice meaty midrange, and earlier spool-up: hopefully with the new turbo manifolds, suction kit and z32s, it should be a no-brainer. Last tune with stock manis, rb26 afm's and stock inlet, it made a safe 297awkw.
Will be interesting to see what happens if it doesn't explode... ;)
keep us posted. what turbs you running? Good luck
Been a productive weekend. Installed turbo side cam gasket, replaced in car filter and ran a 5m USB cable from tv tuner in boot to under front armrest so I don't have to go to boot all the time to change USB stick. Next thing to do is fix boot latch, fix exhaust bolt that I snapped and machine front rotors. All will be done by Friday in time for my trip to Sydney next Wednesday for world time attack next weekend. Tiltons Evo for the top honor!!
297kw atw's is impressive already. Isn't amazing how one becomes accustomed to the amount of power. Here I am with a maybe 150kw's at the wheels? and to think of doubling that and then wanting more seems almost crazy for a street car. But there it is. It only seems crazy until one becomes accustomed to it. anyhoo, i'm jealous :D gimme your cc details and i swear i'll feel better ;)
So I decided to knock up a gauge pod to mount a boost gauge on my dash at the base of the A-pillar the other day.
I started with a yum-cha '1 size fits all' generic A-pillar mount i got for cheap off eBay which i then started cutting into shape, followed by a bit of bogging & sanding
Pics:
And once I was happy with the shape (and many coats of hi-fill later), I painted it with some dark grey paint I had mixed up in a sample pot from Bunnings, applied with a sponge for the textured effect (the colour isnt a perfect match, but its close enough) & then stuck it to the dash with dounle sided tape
I'm in half a mind to re-do it so that the line at the bottom matches the line of the vent underneath it, but finding the time is the problem - that & the fact that I couldn't be arsed. :unsure:
That gauge pod is pretty cool, but did you consider trying to put it in the top vent hole? Nothing much goes in or out of there; I've had mine blocked for ages & noticed no difference.
+1 to Leon, mine is in there ( using.. shock/horror, a bit of garden pot :) )
Its the only non factory thing inside my car- the way I like it. Uncluttered.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
