Got rid of the old paper job and dropped in a K&N filter yesterday. I'm probably imagining it but it feels a little bit more responsive on the pedal. :woot:
Nah, I reckon they make a noticeable difference too.
Finally got some time to fit the greddy oil cooler to the car.....only problem is I am having to move the power steering cooler! :(
Other than needing new tyres and a power steering cooler......also the new rear wing the car is safe to go to the track finally.
I thought Scotty had said his oil cooler makes no real difference?
Oh, and to my Stagea, this weekend I finally got the wideband bung welded in, so just need to wire it up now. Also getting closer to sorting the Fcon out, looking to change some of the wiring around to run the HKS sensors instead of the stockers.
I thought Scotty had said his oil cooler makes no real difference?.
No real difference to performance that is correct!....however the temps generated at full song on a track are a little different....every bit helps. Even if I only do 3 lap sprints "at my pace" on short tracks and it keeps the temps down it will be great. My only stuff up today was that I didn't put the sensor in the sandwich play before filling the oil.
Edited by Jetwreck
Definitely need the oil cooler for the track, as well as a huge trans cooler and the power steering. Not much room left in the front of mine now. With a massive 30 row oil cooler that has a 14 inch thermo mounted to it, my oil still got to 110 degrees at PI, the water hovered around 91 with the stock radiator.
My car let me down today. :( The throttle became unresponsive and I had to crawl home at 20-30kph. (after pulling the throttle plug for some more revs.) I suspected Leon's cruse at first so I disconnected it, no change. Swapped the throttle pedal over, still the same. I even pulled the ecu plug and checked the loom, no problems. It turned out to be the throttle body itself which is unusual, I haven't heard of one failing before. At least I have a few laying around I guess. The best part is it idles on 700 again instead of 1000 revs. Win.
I think the tps shat itself, it read 2.5v continuously at idle. I guess it was in limp mode but I didn't have to reset anything once the new throttle was in... I had a similar experience at PI, had to pit as the car wouldn't rev. It ran fine again once I restarted the car.
Dropped the oil yesterday - well, I started on Sat - but after putting the oil flush in I couldn't find the extra 2L of 300v...and shops were closed..so had to finish it off on Sunday.
Anyway, its good to be driving again.... :banana:
Unless you want to be looking at a constant CEL and an unhappy ECU, I'd be leaving the stock sensors in as well as running the Fcon sensors.
I mentioned that, but apparently you can set it up so the F-con only reads the input from the sensors as they're fed into the stock ECU.
Can't run both apparently.
Which sensors?
I run both, I just cut the wire at the fcon end and can swap between them with bullet connectors. The stock ecu still gets the stock sensor signal as the patch loom goes straight through.
Cam, what were my errors again? I am keen to get rid of them all now. I remember the stock o2 was missing...
I didn't unplug any OEM sensors when I ran the Fcon as I didn't want the damn CEL on all the time.
I'm sure the Fcon can be set up to read the HKS IAT and MAP sensors and ignoring the ECU's feedback for these.
Buggered if I know. Like there is a chance I'm remembering the one that couldn't be removed - let alone the one that were removed!
I'm glad i'm not the only one with a failing memory. :P
I don't know how it works. The guys are modifying the harness to take the HKS sensors and have looked at the VQ25DET ECU pin out to get it all working. I'll see how it goes when it's on.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
